• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Acrobat 9 seems incompatible with Snow Leopard
New Here ,
Aug 27, 2009 Aug 27, 2009
Got my Snow Leopard late this afternoon and have had great luck with it so far (did an upgrade, not a clean install)...except for Acrobat 9. Ugh! Attempting to print to PDF via Adobe PDF 9.0 printer/driver causes the printer/driver to fire up and the progress windows indicates that distiller launches, but after that, the prompt for where to save the PDF to never appears and the file in the print queue disappears. Checking the log file shows quite a few errors are happening:
E [25/Aug/2009:18:35:44 -0500] Unable to execute /usr/libexec/cups/backend/pdf900: No such file or directory
E [25/Aug/2009:18:35:44 -0500] [Job 4] Stopping job because the sheduler could not execute the backend.
E [25/Aug/2009:18:37:12 -0500] Unable to execute /usr/libexec/cups/backend/pdf900: No such file or directory
E [25/Aug/2009:18:37:12 -0500] [Job 5] Stopping job because the sheduler could not execute the backend.
E [25/Aug/2009:21:49:33 -0500] Unable to update IPP DNS-SD record for AdobePDF9 - -65549
E [27/Aug/2009:18:35:41 -0500] [Job 7] Job aborted because the destination printer/class has gone away.
E [27/Aug/2009:18:45:43 -0500] Unable to execute /usr/libexec/cups/backend/pdf900: No such file or directory
E [27/Aug/2009:18:45:43 -0500] [Job 9] Stopping job because the sheduler could not execute the backend.
E [27/Aug/2009:19:38:42 -0500] cupsdAuthorize: pam_authenticate() returned 9 (authentication error)!
E [27/Aug/2009:21:16:59 -0500] Unable to execute /usr/libexec/cups/backend/pdf900: No such file or directory
E [27/Aug/2009:21:16:59 -0500] [Job 19] Stopping job because the sheduler could not execute the backend.
I've done a full uninstall and cleaned out all files, then reinstalled. I did the old repair/restore trick from the Help menu. I even tried printing to PDF after each patch/upgrade all the way to the latest version. No luck at all. And yes, all other CS4 apps I have work fine.
Any suggestions?
Views
57.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor ,
I am going to take a stab. This strictly conjecturer on my part since I don't even X.5.
Try going to Printer Utility, and delete the AdobePDF 9 Print Driver then open. Acrobat and go to help and choose repair installation (use to be repair or replace).
uncheck both items then recheck just Adobe PDF.
choose to replace, or hit return or okay.
Now try. If no help, then you may need to file bug report with Adobe.
another thing you might try is use the uninstaller which removes all (or supposed to) adobe items and components (but not your PDF Files). then reinstall.
Since Snow Leopard is Intel only. a clean install of Acrobat 9 might load strictly intell code.
Votes
Translate
Translate
Report
Report
New Here ,
I appreciate your response, but if you will note in my post, I had already tried all your suggestions.
Votes
Translate
Translate
Report
Report
Mentor ,
Aug 28, 2009 Aug 28, 2009
You now then need to file a bug report.
try Here:https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=15&6213=9
Now be sure to copy over the details above you gave for error messages.
In the interim I would suggest you tempoarily use Apple's built in PDF Print feature. You can still work with it in Acrobat.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
There is a new PDF Service that is installed now.  Have a look at the following KB document.
http://kb2.adobe.com/cps/509/cpsid_50981.html
Votes
Translate
Translate
Report
Report
New Here ,
Steve's tip looks like it's taking me in the right direction...but I've hit another road block. I performed a full uninstall (including manual deletion of application support and preference files) and then a clean install with upgrades all the to 9.1.3.
Using the "Save as Adobe PDF" results in the following error while Apple Workflow attempts to generate the PDF:
"Save as Adobe PDF quit unexpectedly while using the AdobeACE plug-in."
Subsequent attempts result in:
"Save as Adobe PDF quit unexpectedly while using the Save as Adobe PDF plug-in."
All other CS4 applications continue to work flawlessly.
Votes
Translate
Translate
Report
Report
Guest
Aug 29, 2009 Aug 29, 2009
Thanks for posting this.
One problem with this workaround is that I don't seem able use the Save as Adobe PDF option in an Automator Workflow. (I get The action “Save as Adobe PDF” could not be loaded because it is not Universal. Please ask the developer for a Universal version of the action").
Is there any plan to do this? I used to be able to use an Automator print workflow to batch convert Word docs to PDF, but I can't see any way to do this anymore.
Votes
Translate
Translate
Report
Report
New Here ,
I'm wondering if anyone with Acobat 9 and Snow Leopard could tell us if they are experiencing any issues?
Votes
Translate
Translate
Report
Report
Mentor ,
Uh, have you read the above comments??
Votes
Translate
Translate
Report
Report
New Here ,
My point being that it appears we only have 2 posts in these forums so far related to Acrobat 9 issues and Snow Leopard. I'm here to get help and possibly help others who are troubleshooting issues. If you can't post a helpful comment, then please take your trolling to another thread.
Votes
Translate
Translate
Report
Report
Mentor ,
Aug 30, 2009 Aug 30, 2009
Was not meant to be trolling. You asked almost the same question word for word that the original poster asked.
Snow Leopard has only been out two to three days.
There are some reported issues with CS3. But no others related to Acrobat. The reported issues with CS3 are in ZDmet, cNet, and computerworld news flash sent daily.
Votes
Translate
Translate
Report
Report
New Here ,
If you spent less time trolling and more time reading you would have noticed I am the original poster! Please move along as it is obvious you have nothing to offer to this thread.
Votes
Translate
Translate
Report
Report
Mentor ,
Fine. If you ask a question get several results the ask again. makes one wonder.
Votes
Translate
Translate
Report
Report
Sep 01, 2009 Sep 01, 2009
I actually did a clean install of Snow Leopard, and a fresh install of many of my Adobe products from CD. I downloaded Acrobat Reader, but it will not let me open and PDF's. It always gives the same error message: "An internal error has occurred". It remains open, the app then quits, and it will not allow you to Open a PDF via the FIle menu either.
The new Apple Preview saves the day, and is much faster than previous versions.
I used AppCleaner to remove associated files and deleted and reinstalled with a fresh download. Same thing.
Votes
Translate
Translate
Report
Report
Guest
Well Adobe Reader is a whole 'nother kettle of fish .. and not associated with this topic.
Persoanlly, I never use Reader myself .. either full blown Acrobat 9 .. or Apple Preview.
Votes
Translate
Translate
Report
Report
Sep 02, 2009 Sep 02, 2009
"Well Adobe Reader is a whole 'nother kettle of fish .. and not associated with this topic.
Persoanlly, I never use Reader myself .. either full blown Acrobat 9 .. or Apple Preview."
Well then I'd recommend "downgrading" to Acrobat 8 Pro.  It works fine.
Votes
Translate
Translate
Report
Report
Guest
Actually, 9 works fine for me (so far) My initial issue was that I was just choosing the wrong PDF option. I was just trying to brainstorm with others.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
telecommunicate:  This KB ""Save as Adobe PDF" does not load in Automator 64-bit Workflow on Mac OS X 10.6 (Snow Leopard)" might help with the message that you ran into regarding Automator workflows.
http://kb2.adobe.com/cps/512/cpsid_51248.html
Votes
Translate
Translate
Report
Report
Guest
Thanks Steve, I'll give this a shot later today and report back. (I'm a bit pressed for time right now, so I can't give this a go just now.)
Votes
Translate
Translate
Report
Report
Guest
OK, I've tested some Automator workflows using the Save as Adobe PDF option. I can get it to work, but only on files that are already PDFs (as indicated in the Automator action description, but I was hoping it was a bit more robust than that).
Unfortunately, this is much less useful than the Adobe PDF Printer, which was able to handle, well, any type of file that could be printed. Consequently, Automator workflows could involve files of any type, which would print to PDF from their default application. If the files I'm working on were already converted to PDF I wouldn't need to batch process them again.
Votes
Translate
Translate
Report
Report
New Here ,
May 06, 2010 May 06, 2010
Hello,
My Acrobat 9 will not even open. Instant crash.
2GHz Intel Core Duo
Snow Leopard 10.6.3
CS3 Acrobat Pro 9.0
Exception type:EXC_BAD_ACCESS (SIGBUS)
Exception Code KERN_PROTECTION_FAILURE
Votes
Translate
Translate
Report
Report
LEGEND ,
May 10, 2010 May 10, 2010
Try updating to the latest version of Acrobat.
Votes
Translate
Translate
Report
Report
New Here ,
Thank you Michael.
How do I update it if it crashes instantly? I can't open the application at all.
My desktop computer with non snow leopard (10.5.8) no issue.
Votes
Translate
Translate
Report
Report
New Here ,
May 11, 2010 May 11, 2010
LATEST
Hello Michael.
That actually worked.
Since I did an Un Install, I had to downloat and apply about 8 updates, taking a couple hours. But it works now.
Each update has to be installed on the previous incremental version, and at the end, the Serial Number was asked for.
Thanks for your help!
John
Votes
Translate
Translate
Report
Report
New Here ,
I also have Acrobat 9 Professional and after Snow Leopard, I can no longer print. I get the printer launching as normal, but just as 'thewildman', I do not get the save window. The print queue just disappears. I have tried deleting and reinstalling Acrobat, then deleted the printer itself, and using the Repair Installation menu item from help. It works exactly the same. I have also used spotlight to be sure that the files aren't saving somewhere on the computer and just not letting me name them. They are not.
update.. Sorry, I missed the link that someone pointed out that talks about the 9.1 update.. It looks like a kluge fix, but am downloading it now.
Votes
Translate
Translate
Report
Report
