I just recently started using Adobe Acrobat 9. I am recreating a document which will be saved as a pdf form (where the user will complete and return to my attention). The previous document that was used at my company shows the following under the Security Document Properties:
Security Method: No Security, Can be Opened by all versions of Acrobat
Under Document Restrictions Summary--Changing the Document, Document Assembly, and Creation of the Template Pages are not allowed.
This new form needs to mirror the previous security settings. Is the a way to just alter the Document Restrictions Summary page without having create a security policy?
Many thanks.
Have you looked at using "Password" security in the PDF.
Applying Password Security to PDF files by Rick Borstein
Checking and removing security from PDF files by Rick Borstein
Hi All,
I have a similar issue, however mine is as follows.
I'm currently using Adobe Standard 9 and Adobe Reader 9.1
The problem i'm having is trying to enable the measuring tool facility in documents, if i take any particular document and open it using Standard, it says there are no document restrictions in place. If however I open the same document with Reader, it is telling me that there are various different restrictions in place, including commenting, which is why i'm guessing I can't utilise the measuring facility.
There are no security restrictions in place on any of the documents i'm using.
Hope someone can help, as the documentation with Standard 9 is woeful, and the usually successful google search has turned up nothing!
Regards
Martin
North America
Asia Pacific
