Aug 29, 2009 3:55 PM
PS CS4 almost unusable with snow leopard
Like (0)
Installed Snow Leopard. Ran the adobe uninstall for CS3 then did a fresh install of CS4. Downloaded all the updates. When I open Photoshop I get a constant stream of the same error message that reads "Could not complete your request because of a program error" screen shot attached. It makes Photoshop pretty much unusable. I'm not having the same problems with Illustrator. I'm working on a MacBook Pro w/ 1.83 GHz Intel Processor and 1.5 GB 667 Mhz Memory. If anyone could help me suss out the problem I'd be eternally grateful.
Cheers,
Bummersville
I installed Photoshop CS4 after installing snow leopard. PS is crashing when saving JPG files. It is completely repeatable.
I deleted the preferences files and I got it to save the file once. The second time it started to crash again.
The file is a PSD file with several layers it is 4267x1200 pixels.
I then flatten the file and save as .... JPG
As soon as I click on the JPG quality or OK button photoshop freezes. THIS IS REPEATABLE EVERY SINGLE TIME.
The big lie from Adobe is that they said that CS4 was certified to work with Snow Leopard, it DOES NOT.
I went and spent the $350 for the upgrade to find out that CS4 is just as unstable as CS3 (which actually can still save JPGs
but crashes usually while retouching an image with the brush tool).
My machine is a current iMac24 with plenty of free disk space and 4Gigs RAM
I ran disk tools too. no problems here either. Even if I restart and only run PS it still fails.
Adobe you have to fix this. It is completely unacceptable to tell customers to go buy CS4 and have it NOT WORK.
I have used PS for more than a decade and it has been quite good. you have concentrated on bloatware features, too frequent updates to get more money (greed) at the expense of quality.
I do not believe that you are honestly concerned about quality, just more money for overpriced upgrades.
I'm also experiencing numerous crashes in both Photoshop CS4 and Flash CS4 since upgrading to Snow Leopard, rendering them almost unusable. I have to save my files after every move to ensure I don't lose work, but the crashes are so frequent I really can't get much work done. I hope a patch is coming soon.
-R
Everyone Keep in mind that CS4 was designed under Tiger and Leopard. this could very well be an Apple problem. and Adobe fixing it for the new OS could very well breal it for the old OS's. That would be worse. than doing nothing. Early adopters are always going to have problems it the nature of the game. If you are depending on Photoshop to make a living keep what is reliable and stable and only install 10.6 on a computer or partition that is not mission critical.
Yep and guess what apple is saying it is an adobe problem that they haven't had any reports of this. I unchecked version cue and that helped but it is still spotty whether I can save JPEGs or not.
@ Carlos - It is rude and inappropriat to SPAM and hijack other people's threads. Please stop cross-posting your rant it makes it difficult both for those seeking help, as well as those trying to provide it.
@ NoSongs - you need to start with a fresh install od CS4, it sounds like something got botched in your upgrade/install. Remove everything CS3/4 releated and install from scratch. If that still doesn't work I'd suggest uninstalling all adobe products, then a fresh install of 10.6, and then a install of all your adobe products.
Well they have at least one, yours, which means they have had more reports. I used to be the first on the block to have that new system. After bloodying my forehead on my monitor for each new OS release. I have come to the realization that waiting until Apple has about 3 or 4 system patches out, the OS problems are just not worth the hassle. If you have a production machine stick with tried and true until you know for sure that you will not be losing time and energy trying to fix something you have no control over.
Uninstalled/ Reinstalled CS4 and I'm getting the exact same stream of program error messages in Photoshop, I can't seem to do much without one popping up. I can save as jpgs though
!...I just can't do much else really.
I don't think it's unreasonable to have expectations of functional software when it's been "tested and cleared" for the OS, early adoption or not. That being said, I'm not ready to grab a pitchfork and head to Adobe or Apple HQ just yet as the issue could be with my setup...just looking for people with similar issues or better yet, solutions![]()
Cheers,
Bummersville
It seems to be working fine here. I did an install of Snow Leopard OVER 10.5.8. I did not reinstall CS4. So far everything is very stable. I did lose my R1800 Epson printer driver functionality but EVERYTHING else seems to be working fine. Even things like Quicken 2006.
Heya jb510,
Thanks for the help. I'll try giving 10.6 and CS4 a fresh install. Any tips or helpful links for making sure I'm getting all the adobe stuff off. I'm a little skeptical of the adobe uninstall process...but maybe I'm being a worry-wart.
Thanks again,
NoSongs
@ Buko - I have several machines and almost always test major new software before moving it to my main production machine. Even if you don't have multiple machines it's easy enough to setup a dual boot (even on an external USB) and see how things work for you. If you rely on CS4 for a living and don't do any testing before adopting it, then frankly it's your own damn fault.
That said, I'm running 10.6 and CS4 on my production machine right now, and didn't notice the color managment bug in PS on the second monitor I reported in a seperate thread, until I'd started using it on my primary machine. I don't use PS nearly as much as LR, and it's not a show stopper for me.
NoSongs wrote:
Heya jb510,
Thanks again,
NoSongs
Remember what I did was install 10.6 over my install of 10.5.8 that
had CS4 working. I didn't do a clean 10.6 and then install CS4.
Enjoy and good luck!
Thanks, jb510.
I have reinstalled CS4 and did remover everything CS4 in the various
lib folders.
It still crashes after a few tries
@ Carlos - I didn't suggest you reinstall. I suggest that to the originator of this thread NoSongs. As I respond to the other thread you hijacked your bug is probably OS / File related and one I expereinced in 10.5.8. When I had that problem I had to rebuild the file that was giving me trouble. If you want help, start your own thread, in that thread indicate what hardware you're using and if the bug is repeatable all with multiple files from multiple sources, or just files from one source.
I am having the same problem. CS4 crashes everytime I've opened it since installing Snow Leopard. I unistalled then re-installed CS4 to no avail. It doesn't appear, thus far, that CS4 works in Snow Leopard.
Larry, many people are running CS4 under SL without issue. I myself have spent dozens of hours running on the 32-bit kernel and now many hours of the 64-bit kernel. It would be much more helpful if you would detail your hardware, upgrade and install process and what other software/plug-ins your running.
I am having a similar problem. whenever I attempt to place a file PS crashes. I can copy and paste the artwork in to PS and it works but iI need the place command to work.
I have a 24" iMac, 2.8GHZ, 4BG ram, plenty of HD space. PS version 11.01, OS X 10.6
I upgraded to 10.6 with no reinstall of any Apps. put the disc in, hit install
Help!
Help!
Sorry not to be able to help. Just days ago I created 20 images utilizing the place command multiple times, no problems at all (MBP, OS X 10.6, PS 11.0.1). Can't tell you any more than it works for me. The file (PSD) I was placing had smart objects inside it as well, but wasn't overly complicated.
@LarryGRC & @jb510 -
Reverting to 10.5.8 and doing a clean install of CS4 and then installing Snow Leopard did the trick. So far everything is working great (fingers crossed). Thank you so much for taking the time to walk me off the ledge. Karma cupcakes for you both.
Cheers,
NoSongs
I have run CS4 with Snow Leopard installed by three different methods:
1. Default Upgrade method to my Leopard volume
2. Erase and install SL then migrate everything from my Leopard volume.
3. Erase and install SL, install fresh CS4, no migration, no other software installed
All three crash Bridge and Photoshop frequently, especially while using the output module to make PDF contact sheets (crashes while entering the settings).
1 and 2 also crash on quitting the prog, (but my Leopard has spells of doing that too)
Machine is Mac Pro 4 x 2.66 ver 1,1 with 8Gb RAM
Did all the standard stuff before and after installs, permissions, DU etc plus PRAM, SMC. Also trashed the prefs in Bridge and CS4.
The fact that the "erase/install/CS4 only" method crashes tells me that there is something hardware related in my machine (and probably other peoples too) which SL + CS4 doesn't like, and that there is no point in chasing software solutions.
I would be grateful if anyone who is having no problems with CS4 and Snow Leopard could spend a few minutes making contact sheets with the output module...use all the options. I have successfully done several contact sheets, but also had most crashes while entering the settings.
I'm having several crashes with PS CS4 as well after my SL upgrade. bleh.
I've switched PS to open in Rosetta in the hopes it will be more stable. I had installed SL with custom option and installed Rosetta as well. I'll be testing tonight and I hope to report back if this helps my crashes.
My stats are below:
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.5 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 800 MHz
I don't seem to be having any problems. I actually installed over Tiger. I am on a Mac Pro 2.66 5gig of RAM.
Cheers,
NoSongs
This is one sequence I haven't tried, so I am tempted, but I struggle to see how this could work for me when an erase install of SL with a fresh CS4 installed, and no other software, crashes. There must be some other hardware sensitivity going on.
I remember when Leopard came out it exposed hardware issues that Tiger tolerated.
BTW have you tried using the Bridge Output module, that is what seems to crash mine.
We've narrowed down some of the instability issues with Photoshop on Snow Leopard to a font called Menlo. which is new to 10.6. For now, we're suggesting leaving the font installed and avoid using or selecting Menlo in Photoshop.
For additional updates and details see my twitter feed:
Message was edited by: adobe-admin
I've upgraded to Snow Leopard and I've been unable to find this Menlo font. I've looked inside the HD/System/Library/Fonts and the HD/Library/Fonts folder and no luck.
I'm I missing something here?
Thank you. I found Menlo and am testing PS without it. If this works, I'll buy you a beer!
i just removed the font, restarted but unfortunately i'm still experiencing the same crashes (when opening files +random ones).. Any other things we could try?
P.S. The font you mentioned did seem to have issues as it was impossible to preview it with the systems font viewer..
Are any of you with crashing problems using any kind of 3rd party font manager? I have menlo installed and no problems.... note I also use very very little text inside photoshop.
I restored my system and installed Leopard. I don't have time to wait for
Apple and Adobe to discover that they have a problem.
I'm experiencing the crashing, and am running FontAgent Pro. I upgraded to the latest version to see if that would solve the crashing, but it didn't.
I've tried deleting Menlo, but haven't had a chance to work on the system to see if it's solved the crashing problem. I've seen fonts cause problems like this before and it would make sense given multiple apps have become unstable (Flash CS4 consistently crashes on me as well, I haven't done much work in Illustrator or InDesign to see if they've been compromised.)
-R
I've tried all of the above suggestions and I'm still experiencing lots of crashing and errors.
Here are 2 particular problems I've run into: Exporting PDF's from InDesign CS4, crashes every single time. No matter what the file size, amount of links, content. It crashes without fail.
Saving or opening .ai files in illustrator.
The odd thing is SOMETIMES (about 1 out of 20 tries) the errors don't occur. And I can't put my finger on what makes the difference, as I literally change 0 variables.. same programs open, running (safari, mail, etc).
This really needs to be addressed. I just upgraded (? if you can call it that) to Snow Leopard and CS4 in my office, and I'm extremely dissatisfied.
this thread is not "Answered"
That's what happens when you have people who don't no what they are doing claiming they have the correct answer. This is one of many short comings of this forum.
Well I am about to get really annoyed attempting to tell the Dreamweaver forum which is almost entirely Windows people about a problem with Snow Leopard. Where the h*ll am I supposed to take this??
Seems that selecting an image and hitting the return key (which should place it) will bring up the help menu. Sighhh.
What do you say Buko? Should I try?
Buko - The originator of the thread is the one who decides what the correct answer is, not "people who don't [know] what they are doing claming they have the correct answer" as you put it. NoSongs may of taken my advice and marked it as the answer before discovering it didn't resolve the problem but don't go blaming the people here that are actually being constructive and helpful rather than those just wasting time by and anonying those her to help and be helped with thier off topic ranting and complaining.
Apple has a lot of reports from many applications (not just Adobe) about crashes when opening and saving files.
We're working with them to resolve the issue.
Hello, I to am having crash problems on open/save. Goes for illustrator and flash as well. How do I get my working version back? Can time machine send me back to when everything worked fine in regular leopard? AHHHHH I am a mess, this is sooo fustrating!
-Cody
-Cody
To recover to a time machine backup:
http://docs.info.apple.com/article.html?path=Mac/10.5/en/15638.html
You'll have to reinstall MacOS 10.5.8, or wait for Apple to get out a patch.
+1 for it "just works".
I updated from Leopard to Snow Leopard on an iMac 7,1 and see no problem with PS CS4 (so far).
I created a simple graphic, included some text with Menlo font and saved as a JPG no problem.
Cheers
Do you have version cue installed? This is one thing I do not have installed and I have no crashes in the last two days. I had more crashes with 10.5.8. It appears a lot of others do not have crashes with PS 11.0.1 and OS 10.6 either.
To say you have to go back to MacOS 10.5.8, or wait for Apple to get out a patch is a bit premature since this does not seem to be an issue that everyone is having. I sure you don't want to hear this but it sounds like you need to diagnose your specific system. I would start with fonts, profiles and any third party add-ons, to the OS or Plugins.
Um, which one of us has all the crash reports and knowledge of the underlying cause?
Don't take my comments personally. I know you have crash reports and knowledge of the underlying cause, but I was just pointing to someone that wanted to leap to the bleeding edge that he was going to have to do some diagnoses on his part because what ever the underlying causes are it is not causing everyone crashes.
So if you have knowledge of the underlying cause can you not give some information for those that are having crashes to look where to correct it, being specific software or hardware related?
***UPDATE***
I uninstalled CS4 and ran the clean sweep program from Adobe. I reinstalled and still got crashes on save.
I poped in my leopard 10.5 disk and time machined back to when everything was working and now I can work again! I think I am going to wait a while for this issue to iron out before I attempt the snow leopard upgrade again. Thank you Apple for Time Machine, it's saved my butt twice now!
-Cody
This sounds like it may be what I have to do unfortunately...
I've re-installed, cleaned, erased preferences, deleted fonts, all of the above. And I keep crashing on a consistent basis on saves (especially saving or exporting PDF's from indesign and illustrator) Its extremely frustrating.
I was way to excited this week to upgrade to both CS4 and Snow Leopard at the same time. Should have known this would happen!
Can't wait for this issue to be resolved, but I'm glad I'm not the only one. I hope both companies recognize there is an issue with their software.
Sounds like this may be somehow related to specific hardware/driver
issues.
ok.. im having the crashes when opening files that take longer than a few seconds to open (a 1.2Gb file will ALWAYS crash while a 2 mb file opens fine most often.)
My hardware:
i upgraded my (flawless) Leopard install
I have an ATI Radeon as well --- I wonder if that could be the common denominator?
It's unlikely video related, video cards are so standardized on Mac's that usually if that were the case it would effect a much larger population of users. Obviously I don't know what the problem is, and some ATI cards were problematic with VM Ware Fusion and 10.5.7... so who knows... personally I'd lean towards the tablet and/or 3rd party drivers for the external hard drives being the trigger.
I've unplugged both of those things, still get crashing on 2 different machines during pdf exports, or saves (MacPro 2 x2.66ghz dual core intel xeon 3gb 667mhzddr ram) and a macbook pro (dont know spcs)
Is this something we wait for apple or adobe to correct you think? --- or is it something I have to tweak on my machine(s)
In the meantime I'm going back to CS3 I guess..
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
