AFTER EFFECTS WISHLIST
Aug 31, 2009 8:39 AM
  Latest reply: genoden, Mar 26, 2014 10:37 AM
Replies 1 2 3 4 5 ... 9 Previous Next
    Feb 4, 2010 3:27 AM   in reply to Andrew Yoole
    OMG, y'all!  Please fix this whole model dialog box warning hell. How about an error panel, similar to Growl (if not supporting Growl directly)?
    Here's what I had to put up with this morning.  I freakin' get it -- you can't find a font!
    Do I really need to be alerted by every single layer that uses it? And does it need to completely tie up AE until I click 'ok'?
    Feb 4, 2010 5:37 AM   in reply to Andrew Yoole
    Now all new projects are in full HD. If we want to continue using After-Effects with compositions of 50-100 layers, we need an X64 Bits version which quickly manages multithreading.
    Feb 4, 2010 5:43 AM   in reply to Andrew Yoole
    How about an option to (If it doesn't already exist and i'm too blind to see it) shutdown your computer once a render or group or renders in completed?
    I hate leaving my computer running for any longer than I have to so if I go to bed or what have you I don't like leaving it on for hours doing nothing.
    Feb 4, 2010 5:49 AM   in reply to noel_d3
    I'm sure you know that AE product manager Michael Coleman and Adobe announced that AE CS5 will be 64bit only.
    Feb 4, 2010 5:51 AM   in reply to Navarro Parker
    Hear, hear!
    This happens in a number of places in AE:  expressions errors, overwrite file warnings, and so on.  It's particularly bad with overwrite file errors, since it is often impractical to delete all the files you are trying to overwrite first, at least in the case of image sequences (because they typically need to be in separate folders), and if you dismiss the dialogues using the keyboard and hit "return" one too many times you end up stopping the render you were trying to start.  For warnings like that, an "Apply to all" checkbox would be a big improvement.
    Feb 4, 2010 6:15 AM   in reply to Andrew Yoole
    i just want adobe to put mocha inside ae and buy the rights of some plugins like " trapcode particular" and "Zaxwerks 3d invogorator or animator" so the package must come with these....
    and also i want 3d motion tracking in ae...
    in addition to these also "direct linkingof ae camera moves  to 3ds max cameras or opposite" would be nice!
    Feb 4, 2010 10:37 AM   in reply to Andrew Yoole
    I'd like to either see After effects become more similar to something similar to nuke with true 3D compositing and a legit nodal way to composite, but if that is too much of a learning curve form the tried and true adobe interface and techniques what about integrating it with premier almost like having a premier light built into it. Instead of Ram previewing you could have a composite timeline and an NLE master timeline working together within the same program. I realize that Adobe had dynamic link - it doesn't really work well at this point. Stu Maschwitz has an interesting take about this on his blog: Prolost.
    I think one way or another though after effects needs a bit of a serious overhaul in either direction as it feels like the last few iterations have not kept up with some of the newer technologies that have come out (don't get me wrong - I love After effects, but it could always be better).
    Just my 2 cents.
    Feb 4, 2010 11:20 AM   in reply to TrustyThompson
    look for  "" A_Render_n_Shutdown_v1_2.jsx ""
    Feb 4, 2010 11:31 PM   in reply to Sébastien Périer
    I hope the old versions of plugins will be compatible with 64-Bit version.
    Indeed the price of plugin I use is higher than After Effects and the development of many plugins is stopped.
    It's the role of Adobe to make this compatibility possible, otherwise it would remove many functions in After Effects ...
    Feb 17, 2010 12:11 PM   in reply to Andrew Yoole
    Here's a no brainer -- how about adding "Reveal Composition in Project" when you right click a comp tab?
    (As it is now, you have to find a blank area without any layers to right click in, right?)
    Feb 17, 2010 12:56 PM   in reply to Andrew Yoole
    This thread is too big to read it all, so I apologize if this was brought up before:
    1. For us, Windows users, can you please include Cut, Copy, Paste, Delete into the pop-up context menus. (I know, Adobe crowd uses keyboard shortcuts, but I spent too much time in Windows and do it faster with the mouse right-clicks and menus)
    2. In case of autosave, can you PLEASE remove that annoying message box window when the autosave happens? Mine is set to once every 5 minutes and what happens is that if I'm working on something, like adjusting a mask, or something involving dragging of a mouse, when the autosave message box pops up it throws the mouse process, or selection off. This can be very annoying at times.
    3. Maybe there's a way to speed up the loading process for AE. By that I mean selective loading of plug-ins "on-demand", or load them only when we need them.
    PS. Thank you to whoever started this thread. Also thank you to Adobe people that might be browsing, and hopefully listening to this.
    Feb 17, 2010 1:33 PM   in reply to DC B. 09
    You can rt click and select a command form a contextual menu and then click it faster than you can hit Ctrl-C?  I doubt it.
    Not trying to be an *** here, but for the few times that I DO use contextual rt click menus, I would be ANNOYED if I had to look at those extraneous commands each time.
    Let me help you with the hotkeys:
    cut - ctrl/cmd-x
    copy - ctrl/cmd-c
    paste - ctrl/cmd-v
    delete - ummmmmm
    As for the autosave, are you talking about the indicator that it is actually saving it?  Because I don't know of any other message boxes.  If that is what you are talking about I think this would be virtually impossible to remove as it is just going through the process of saving.
    I personally don't use autosave, and this is one of the reasons I don't.  I don't want it interrupting my workflow.  But after years of working and having been brutally BURNED a few times, I generally save a few times per MINUTE, unless the project is getting too large, and then I save as often as I can without severely slowing me down.
    Oh, and that's save - ctrl/cmd-s
    Feb 17, 2010 4:29 PM   in reply to Chas Naylor
    Chas, I agree that most Adobe products are made with an assumption that the keyboard shortcuts will be used instead of context menus (that is mostly due to Mac users that didn't even have right mouse buttons). But again, in my case, by being a long-term Windows user -- this is a habbit that I cannot really do anything about. I also agree that inclusion of such context menu commands may distract the "loyal" AE users, but they may be added upon request in the Preferences window.
    As for my personal opinion about keyboard shortcuts, then I definitely like them and use them as well. Obviously, Cut/Copy/Paste are the most commonly used (and universal) ones. But, in my opinion, there are several issues that may arrise due to excessive number of keyboard shortcuts in a product (like AE), namely:
    1. For a user interface as "busy" as in AE, it is sometimes difficult [for me] to tell what control/window/pane/element is currently selected. (It is not as strongly highlighted as in other software products.) Thus simply hitting Ctrl+C may copy something that I did not intend to copy, and believe me I've done it so many times. But, right-clicking an element and seleting Copy from the menu will guarantee that the intended element is copied.
    2. Having too many keyboard shortcuts may result in an inadvertant activation of some unintended function. I've done this so many times as well. I may accidentally hit a keyboard button, or do it when something else is selected and "mess up" a layer/value only to discover it later when it's too late to undo the damage. (I understand that layers/masks have locks for this purpose but lets face it, it is quite easy to forget to lock a layer or a mask.)
    Now regarding the autosave window. I do know about the Ctrl+S shortcut (it is also kinda universal). I was like you, heavily relying on my memory to do the trivial task of saving.... I started using the autosave option after AE suddenly crashed after about 15 minutes of my intense work when unfortunately I didn't remember to save the project manually. And, AE is very good at crashing, especially on complex projects. It taught me a lesson and, as a side note, this autosave option works great except this little nuisance with a popping message box.
    And yes, you understood it right. The message box pops up when the actual saving is done to tell me simply that :). But there's one thing I will disagree with you, and that is that this message is absolutely essential. I'm a Windows developer myself and I know quite well that both Windows and OS X are multitasking systems and the job of saving the project can be done in the background thread without the interruption of the workflow. (That is how it's done in the MS Office, for instance.) So it is absolutely possible to accomplish this, and the way it should be done is through a status bar message (at the bottom of the main window) that will not switch a current keyboard/mouse focus to itself like the message box does.
    Feb 17, 2010 4:33 PM   in reply to Andrew Yoole
    You know, there's one more "request" I want to add: Is there any way to add a Text field control to the existing Slider, Checkbox, etc. in the Effects -> Expression controls?
    Feb 17, 2010 5:02 PM   in reply to DC B. 09
    See and I feel like, compared to many of the apps that I use (IE - autodesk stuff), the AE interface
    is quite clean and lacking in "busy-ness".  And I feel like that big yellow border
    around the currently selected window is clear enough.
    But that's not important, what is, and where we can agree, is that AE just needs to pony up and make its hotkeys CUSTOMIZABLE, just like almost any other powerful app that I use.  Max, Maya, Logic, etc etc.  This is the BIG BOY step that AE NEEDS to take.  Please please please.
    FOR EXAMPLE: With customizable hotkeys I could at least fix the HIDE hotkey that Adobe insists on being a primadonna about on the mac platform; it is the only suite I have ever used on OSX that needs an additional modifier besides the universal cmd-H.  I mean, c'mon, REALLY?  I know this sounds like a niggling detail, but it is annoying, and a customizable set of hotkeys could do away with this, and other, annoyances.
    This would also solve your issues, Dan, and also make the app MUCH more customizable for the rest of us.  Of course at this point there might not be much I would change since I have been forced into the same hotkeys for going on ten years now.  But like I said, STILL MAD about the ctrl-g thing.  Like Wayne and Garth said: we fear change.  Or FORCED change, at least.
    As for the saving thing, yeah I don't write apps so I defer to your expertise in this, and you are probably on to something there.
    As for the text expression control: interesting idea, but how would it be implemented?  What would it control?  I can't really think of a way that this would give you anything over what the over controls do, with the exception of the source text property.  And controlling that with an extrenal controller would be redundant.  I'm not saying this isn't a good idea, or that their ISN'T a use for it, I just can't think of what that use might be."
    Feb 17, 2010 5:07 PM   in reply to Chas Naylor
    They are customizable. There's a file that defines the shortcut keys, and you can modify that file. We even provide a script with a pretty friendly user interface (KeyEd Up) for folks that don't want to open the file in a text editor. See "Keyboard shortcuts".
    Feb 17, 2010 6:27 PM   in reply to Chas Naylor
    Yes, I agree Ctrl+Shift+H for such an often-used option is a stretch. And, yes, shortcuts are customizable. Although I wouldn't do it if I were you since if you customize it on your local system and then switch to another copy of AE without such customization you'll be lost.
    The text expression control could be a good addition to the AE interface. Here's why:
    1. Picture this. You have several layers that display the same text (main layer, shadow layer, adj layer, etc). Currently you have to link the text source fields together, but say, what if that text has to change dynamically (via another script or with the use of keyframes). That's what a text expression control could be very handy for. One can simply add it to the Null adjustment layer along with custom checkboxes, sliders, etc. At the current stage I have to use a separate text layer and link to its text source and make it invisible, that is not as convenient as having a standalone keyframable control.
    2. If you noticed, the current user interface in the AE does not have a text field control (it has a number control, but that is different). Such control was actually needed to implement some properties in some effects (ex.: Path Text, where to change the text of the effect one needs to click Edit Text link to open a pop-up window).
    Feb 17, 2010 6:34 PM   in reply to Chas Naylor
    Here's an example of an ambiguous selection. Say, if I want to copy the mask of a layer. When you select it there's absolutely no CLEAR indication that the mask itself is selected and not it's parent layer itself (well, one can tell by looking at the keyframes on that mask, but what if those keyframes aren't visible)....
    Feb 17, 2010 8:03 PM   in reply to Todd_Kopriva
    Yes yes, Todd, technically you are correct.  I should have been more specific.
    Adobe needs to implement a NATIVE way to customize the hotkeys (IE - within the app itself).
    The way it is set up now is basically a prefs hack.  It may be a sponsored hack, and it may work just fine, but it still isn't the same as having the ability to change the hotkeys natively.
    I know what you're thinking: "so what?  They would both do the same thing and the current solution works fine."
    And I agree with you to a point, except that I teach motion graphics at a design school, where our machines are frozen and prefs are reset everyday.  The current solution incurs too many variables and issues to make it fully usuable in our current situation.
    So yes, boxes outside of my school I could set and forget, but without the ability to natively customize hotkeys within the app there are problems that perhaps the adobe engineers did not consider
    Feb 17, 2010 8:05 PM   in reply to DC B. 09
    function(){return A.apply(null,[this].concat($A(arguments)))}
    Right, I think that's just where you have to get a handle on what is actually selected via the time
    line.  I dunno of a way around this, except maybe to implement some sort of sub-object selection mode like Max and Maya incorporate
    , where you could ONLY select certain properties.  But that might get messy, and layers are not
    the same as 3D models.
    Feb 17, 2010 8:12 PM   in reply to DC B. 09
    I teach a method to fake 3D extruded text using an epression to place a layer in z-space based on index value, and then duping that layer until you achieve the desired thickness.  In this case I simply link the source text to the original text layer on the first dupe, and then THAT layer is the one I pull out for the extrusion.  I never hide anything to control the source text.
    Maybe I am just not getting it, but I don't see the point of having a source text controller on a null to do this same thing.  It seems redundant to me.
    I'm not trying to be hardheaded here, I really want to understand what it is that you are trying to convey, if it involves more than what I described above.  Because I love expression controllers and the idea of a text expression controller is intriguing, just can't clearly see the use for it yet.
    Feb 18, 2010 11:25 AM   in reply to Chas Naylor
    It simply makes it tidy if text field control can be grouped with the rest of expression controls, and if you read my example, it eliminates the use of a separate text layer.
    Feb 18, 2010 7:28 PM   in reply to DC B. 09
    I believe this is accomplished now by pickwhipping to a text layer's "Text Source" property... which is also keyframable! By having an Expression text control, you'd lose all sorts of formatting and manual kerning. If you have used any old effects that require you to type into a text box, it's a pain.
    How would a text box be better?
    Feb 18, 2010 7:28 PM   in reply to Andrew Yoole
    If you use the Duplicate command on a folder, the new duped comp references the old footage. To me, that doesn't make sense.  Everything in the duplicated folder should reference the same files, but in the new duplicated path.
    I wish this would get "fixed", or have an option for relative vs.  absolute duplicates.
    Current Behavior (absolute path)
    Desired Behavior (relative path)
    Feb 18, 2010 7:56 PM   in reply to Navarro Parker
    That's what I typically do, though there are some instances where I find using the layer name or even a property name (for properties with editable names) is a better solution.
    That said, if you are using any of these methods to put text into a text layer's Source Text property, you will lose all that special formatting anyway. Every character will be formatted with the properties of the first character in the modified text layer's original source text.
    Feb 18, 2010 8:00 PM   in reply to Navarro Parker
    The complicating factor here is that folders in the project panel don't necessarily reflect the structure of the comp/footage networks you want to duplicate (i.e. the source footage or nested comps might be on an entirely different path).  I'd like to see a "duplicate comp network" command to do what you are requesting.
    I keep meaning to write a script to do this, but I never quite get around to it.
    Feb 20, 2010 12:47 PM   in reply to A. Cobb
    I completely see your point of view.  But to me, when you hit Duplicate on a folder, you are cloning the folder "universe", so assets should refer to the relative paths in their "solar system" if possible.  The behavior I want is the same as if I did a collect file, then imported that aep as another project.
    Feb 20, 2010 2:35 PM   in reply to Navarro Parker
    I'd definitely like this capability without the hoops you currently have to jump through to perform this task now, but I'm not sure I'd want this to be the default behavior when duplicating a comp.  There are plenty of instances in which I want to duplicate a comp but have the duplicate reference the original nested comps.
    Feb 20, 2010 7:22 PM   in reply to Andrew Yoole
    I'd like to see a Premiere Pro -style cross dissolve effect. Maybe there is some better way that I'm not aware of, but at the moment I'm creating cross dissolves by adding opacity keyframes, which can get a bit tedious if you need a lot cross dissolves in your timeline.
    Feb 22, 2010 7:57 AM   in reply to Andy Bay
    I haven't checked to be fully sure, but I'd bet 99% that there is something like this in the animation presets.  I do my xsitions by hand so that's why I am not fully sure.  But research animation presets and you will find what you are looking for
    Feb 23, 2010 5:43 PM   in reply to Andrew Yoole
    I'd love the ability to access the Mesh data of the puppet tool via script. This would allow the export of the vertex points and let you do things such as creating puppet-like animations in real time in Flash (easily using engines such as Away3D, or custom built for this purpose).
    Feb 27, 2010 2:05 PM   in reply to Andrew Yoole
    How about this one -- I'm sure someone brought this up before -- the ability to open more than a single project at once.
    Feb 27, 2010 5:44 PM   in reply to Andrew Yoole
    The "Fade In Over Layer Below" preset will automatically fade one clip into the other and the transition length is based on how much the clips overlap eachother.
    Feb 27, 2010 6:08 PM   in reply to Andrew Yoole
    Thanks guys -I was hoping there would be something like that! I was simply searching with the wrong terms like "cross" and "dissolve"
    Feb 27, 2010 7:26 PM   in reply to Andrew Yoole
    How about an HDR color picker?
    These guys are doing some really interesting things with HDR color and negative light.
    http://www.filterforge.com/download/beta2/hdr-support.html
    Feb 28, 2010 3:46 PM   in reply to Andrew Yoole
    The main reason I use photoshop over AE in some situations is the  ability to make good selections/mattes.
    I would like to see the possibility to make photoshop-style selections also inside AE. For example,  it would be nice to have a magic wand/quick selection kind of tool that would automatically create mask shapes on layers based on mouse clicks.
    Mar 4, 2010 2:15 PM   in reply to Andrew Yoole
    I suppose this has been mentioned before:
    Have AE treat image sequences like single files in the file dialog box. (Much like how Lloyd Alverez' "Immigration" script works) A real time saver when dealing with multi-pass 3D renders.
    Mar 6, 2010 11:59 AM   in reply to Andrew Yoole
    I'd like to be able to affect comp settings (dimensions-wise anyway) by using a Comp Crop Tool.
    It often happens I'd like to downsize a comp based on something that's already placed within a comp.
    Currently I need pull up the Comp Settings to do this.
    If I have an element/elements not exactly in the center, then they need to be moved as I tweak the comp size down.
    A Comp Crop Tool would be really, really handy.
    Mar 6, 2010 12:23 PM   in reply to John Stanowski
    Yes, I agree, it would be nice to visually resize the comp instead of messing with numbers. Sometimes it might be handy.
    As for your resizing dilemma, John, you can use Anchor buttons in the Composition -> Composition Settings -> Advanced tab, which by the way, definitely have to be moved to the Basic tab of the Comp Settings window.
Actions
Bookmarked By (1)
