Gurflob
Easiest way of converting motion tween to frame by frame.
Sep 14, 2009 6:36 PM
In the old motion model it was as easy as highlighting all of the frames, converting them to keyframes then removing the tween. But I have no clue how to do it with the new motion model.
    Sep 15, 2009 1:28 AM   in reply to Gurflob
    Why would you like to do it?
    Now it is so much easier to create and edit your motion tween. You can use Motion Editor Panel to adjust every single frame...
    Sep 15, 2009 1:36 AM   in reply to Gurflob
    u can use the old motion by
    Create Classic Tween
    not
    Create Motion Tween
    then do what ever u was doing on the old flash
    Sep 15, 2009 6:51 AM   in reply to Gurflob
    One way I have seen is to create one of the new motion tweens in a CS4 file, then save the file as a CS3 file.  For whatever reason it converts the tween to frame by frame.
    Sep 15, 2009 10:53 AM   in reply to Gurflob
    It's actually much easier in CS4 with the new motion tweens. Just right-click the tween and choose Convert to Frame by Frame Animation. Flash does the rest for you.
    Sep 15, 2009 10:56 AM   in reply to Ned Murphy
    "For whatever reason it converts the tween to frame by frame."
    Flash does this because Flash CS3 doesn't know anything about the new motion spans. So this is the way your animation can be displayed in an older version of Flash.
    (And it's why we added the feature to right-click a frame and convert to frame-by-frame animation - same operation, but allows you to do it for a single span instead of all spans across the entire document).
    Mar 9, 2013 9:33 AM   in reply to Jen deHaan
    How does one convert a frame by frame animation back to io a "normal"
    animation?? Is it possible?
    Thank you
