Changing Thickness of Lines Created with Rectangle Tool in CS2?
Sep 15, 2009 4:35 PM
I am trying to change the thickness of the lines for a rectangle drawn using the Rectangle Tool in Photoshop CS2.
I can not figure out how to change the thickness of the lines of the four sides of the rectangle before I draw the rectangle using the Rectangle Tool or after the Rectangle has been drawn. The same problem seems to occur when using the Polygon Tool, Ellispse Tool, etc.
I can transform the rectangle to make it bigger or smaller, etc. but it seems like I should be able to vary the thickness of the lines for a rectangle.
Is this task possible in Photoshop?  It's simple in Illustrator - this seems like it should be a pretty simple task in P-shop.  I have looked on Google and in Help for P-shop CS2 for an answer but can not locate a solution.  Am I not seeing something really obvious?
Any help is greatly appeciated.
Thanks!
    Sep 15, 2009 9:48 PM   in reply to reyam1
    This depends on how you are using the Rectangle tool. You can set this in the Option Bar.
    If you're making a Shape, you need to change the size in the 'Stroke' field of the Layer Style.
    If you are just making a Path, choose a desired brush size, and then Stroke the Path.
    Sep 16, 2009 4:07 PM   in reply to reyam1
    You'll just have to accept that Photoshop is primarily an image editing program with a few limited vector tools.
    That's why we have Illustrator, which works together with Photoshop.
    Sep 16, 2009 5:03 PM   in reply to reyam1
    Read post 1 again. You want to use layer style (double click to the right of the layer name in the layers panel) and use the stroke option. You can even set layer styles to be applied to objects in one click. So if you commonly need the thick rectangle, it will be one click away.
    Layer style presets are just that, presets, and cannot be changed on the fly quite like true styles, but they're still very useful.
    Sep 16, 2009 9:24 PM   in reply to reyam1
    The Layer Styles method has a distinct advantage in that it remains "live": if you edit the path, the stroke will follow along.
    Stroking the path with the Brush (or any painting tool) is a one-shot deal. If you edit your path, you have to re-stroke. The advantage is that you can use any brush you want, or even something like the Eraser or Clone Stamp (good for removing power lines from a sky).
    You can either access this from the Paths palette menu, or select a painting tool, and press Enter to stroke the path with the selected tool.
