Security Key?
Sep 25, 2009 5:32 PM
I've been running Production Premium CS3 for a couple of years with no problems.  All of a sudden when I start either Premiere Pro CS3 or After Effects CS3 I get the following error message:
"The security key for this program currently stored on your system does not appear to be valid for this version of the program.
Select Yes to enter a new key, or No to revert to the default setting (if any)."  There are 3 buttons (yes, no, and cancel).
If I select "yes", I get the following dialog box:  "Enter registration name and key below, exactly as given to you.  Hardware fingerprint:  C1C9-BC5A" and then a place to enter the name and key.  I have no idea what "registration name" it is looking for.  It is not the product serial number because I tried that and it didn't work.  I'm also not sure if these error messages are for Premiere Pro (or After Effects) or is it for one of the add-ons I've installed.
Anyway, since I cannot figure out what registration name and key to enter, I can hit "cancel" and the program will continue to load again and after a few seconds (and some plug-ins having loaded), I get the same original message.  I can hit cancel and it will continue again.  This will happen 6 or 7 times before the program finallly finishes opeining.  Although this is a very frustrating procedure, the funny thing is that I have not been able to find any problem with Premiere Pro (or After Effects) once I get through all that and the program is running.
I was wondering if anyone has any idea what is causing all these error messages when I open the programs.  The one interesting thing to me is the mention of a "Hardware fingerprint."  I recently had a problem with an XP update and had to reload my chipset drivers.  I'm wondering if this might be causing the problem.  Any help will be greatly appreciated.
