I am having trouble importing translated XML files back into Captivate. In fact I am unable to import an XML file that was just exported from Captivate. I am using the Demo version: Captivate 4 Build 1596.
I've exported XML files for all of my project files directly from Captivate.
I've made the translations within the <source> and <g> tags of the XML file.
I've selected "import XML" from the file menu and I get the error message:
"Import was not fully correct. For information about errors please check log file:"
When I open the XMLImport.log as specified it reads "Caption item RTF was not read" anywhere from 6 to 20 times depending on the file.
What is the problem?
Is this a limitation of the trial version?
Is there a formatting issue? If so why can't I import the XML that was just exported from the software either with or without making changes to it?
Before I ran into this problem with my final translated XML files, I had been somewhat successful with a test run of this exact procedure. I had to make minor tweaks to the XML, such as deleting blank spaces inside the text strings but I eventually got the import to work. This was even with Asian languages.
THANK YOU
Hi there
As described at the very beginning of the Frequently Encountered Issues topic, the trial is not crippled in any way whatsoever, so you can rule this out as a possibility.
I suppose the question I might have here is to ask what you used to make the edits to the XML? I just exported a Captivate to XML and edited the XML using Windows Notepad. Things sailed right back into Captivate with no issues. I thought perhaps I'd see a difference in the different encodings one may save as:
I tried saving as each different encoding and nothing prevented things from round tripping back into Captivate without issue.
Cheers... Rick ![]()
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
So we still don't know the cause..?
I've got the same issue, but Captivate tells me "Import was successful". This is patently untrue as it gives me the the same message even in a new, blank project (which stays blank after "import")!
Whither anon? If this doesn't work then I have no reason to purchase it. If it does, I do.
@Spamhunder: I'm a little puzzled by your post here. Are you trying to export XML from an existing project, translate text, and then import it back into the same project to upldate captions etc. Or are you trying export XML from an existing project and import that XML into a new blank project? Can you explain what your purpose is?
I'm having zero luck with xml i/o as well. It simply does not work. I'm round-tripping translations in a bloat-heavy Word file instead, which is adding significant overhead to what should be a simple translation import.
Adobe: Please fix the XML import/export. It doesn't work. I've even used a bare-bones text editor checking encoding of files and such, even making one solitary change just to test with. Nothing imports.
North America
Asia Pacific
