JRun4 Updater 7 & IIS7.0
Sep 30, 2009 5:34 PM
Hi there,
I am currently in the process of migrating my dev environment from JRun4 Updater 6 with IIS5.1 on an XP machine to JRun4 Updater 7 with IIS7.0 on a Vista machine at work.
I have reviewed the JRun4 Updater 7 Release Notes, following the relevant instructions therein.
I am having trouble with the connector.
I am unable connect from IIS to JRun. Initially, I had tried to add jrun_iis6.dll and jrun_iis6_wildcard.dll as ISAPI filters at the site level and was receiving 503 errors. Following some research, I discovered that adding ISAPI filters was not necessary, so instead deleted these settings and then enabled ISAPI Extensions via Windows Features. This change required that I added the jrun_iis6_wildcard.dll to ISAPI and CGI Restrictions with a restriction of 'Allowed' and also that I added a script mapping in Handler Mappings. I am now getting the error:  HTTP Error - Not Found 404.2 The page you are requesting cannot be served because of the ISAPI and CGI Restriction list settings on the Web server. I then discovered that the sub-error code means "Denied by policy. The request ISAPI or CGI program is not allowed in the Restriction List". So, with this in mind, is the jrun_iis6_wildcard.dll the correct extension to allow, and if so, what may have gone wrong?
Thanks!
    Oct 1, 2009 4:42 AM   in reply to punchyV
    Have you installed IIS Metabase and IIS 6 configuration compatibility for IIS 7? If not I would try installing that component and run wsconfig again.
