Ferry@Mekon
Imported swf files not fully shown on Export
Jun 16, 2008 7:03 AM
When importing an existing swf file in a Cp project (Import > Animation) and setting the timeline for the animation to Duration of Animation, the following happens:
  • During a preview, the animation is fully shown.
  • On Export as Standalone or SWF, the animation is no longer fully shown, but is shortened by several seconds.
Other options not tested.
The way around this is to increase the value significantly and manually time the duration of the exported file (note that the import time is not always correct either) and add the times value in the timeline. It is trial & error and time consuming, but it works.
    Jun 16, 2008 7:12 AM   in reply to Ferry@Mekon
    Welcome to our community, Ferry@Mekon
    You might give the following setting a play and see if it helps. Edit the properties of the animation, click the Options tab and enable the setting labeled Synchronize with project.
    I'm not sure if that will help, but may be worth trying.
    Sincerely... Rick
