Convert Color PDF to Black and White
Oct 15, 2009 9:55 AM
Acrobat Standard 7.0
Mac OSX
Hello,
If I'm given a PDF with color i.e., graphs, charts, etc, how can I make the PDF black and white?
    Oct 15, 2009 10:04 AM   in reply to ryzerman19
    The easiest way would probably be to print to a .ps file using a B/W PPD and the distilling the resulting file back to a PDF.
    Oct 15, 2009 11:31 AM   in reply to ryzerman19
    If you could use perhaps Photoshop if you have it to remove the color.
    Or a Graphics Program I love to use GraphicConverter It has a setting in which you can remove color. you can save in any Graphic Format and PDF as well. Cost about $70.00  but once you buy it incremenatl versions are free and major upgrades are dirt cheap.
    Oct 16, 2009 6:18 AM   in reply to ryzerman19
    Distill to a PDF, then in Acrobat go to tools> Print Production>convert colors> Device gray: Convert> Profile: grey gamma 2.2> don't embed profile.
    Use advanced> output preview to toggle the black separation on and off to confirm the file is black only.
    Oct 16, 2009 10:22 AM   in reply to ryzerman19
    Print to a .ps file using the PPD of any B/W printer like an HP 4100, then distill the resulting .ps file.
    Sep 7, 2010 8:17 AM   in reply to Larry G. Schneider
    Kinda scary-easy...
    Go to File
    Select Print
    Change printer to Adobe PDF
    Go to the properties tab
    Find the button to click to change it to Black/white, and click it
    Print the document - it will ask for a file name, so give it something different from the original or you will overwrite the original
    Open the new document if it doesn't open automatically.
    It doesn't always handle images well, and is truly black and white, but hey, it sure saves on printer cartridges!
    Oct 22, 2010 10:04 AM   in reply to Luke Jennings
    Thank you.  Luke's process (post #5) worked, but the resulting document is larger than my color file.  I am trying to reduce the size of my file, is converting to Black and White not a helpful way to do this?
    Oct 22, 2010 10:41 AM   in reply to asrichman
    After converting the file, did you do a "Save As" (not "save")?
    That should get rid of any extraneous information that is not needed any more.
    Oct 22, 2010 10:42 AM   in reply to asrichman
    If not, under the Advanced Menu is PDF Optimizer where you have different settings to reduce the file size.
    Be careful not to sacrifice quality of the file just to stuff it small enough to email. If you can't make it small enough, there are many FTP options you can look into.
    Oct 22, 2010 11:14 AM   in reply to Russell Goodman
    Thanks for the quick responses.
    Save as gave me exactly the same file size -- still almost 50% bigger than the color file.  Any idea why the greyscale (I didn't do BW, I did greyscale) file would be larger than the color file?
    Andrew
    Oct 24, 2010 3:19 PM   in reply to asrichman
    Different compression setting to the original file?
    Aug 25, 2011 12:45 AM   in reply to ryzerman19
    Though you are asking about Acrobat 7.0, this post describes how to do this very well in Acrobat 9 Pro.  Maybe older versions are supported as well.
    http://blogs.adobe.com/acrolaw/2009/10/converting-color-pdf-to-greysca le-pdf-an-update/
