bboldi
Error #2035 but only on MAC OS ??? why ?
Oct 18, 2009 5:28 AM
I have an application that displays swf files when user selects them with a file browse dialog. here is the code:
             private function dispDialog():void
                var file:File = File.desktopDirectory;
                file.addEventListener(Event.SELECT,onFileOpen);
                file.browse(new Array(new FileFilter('SWF','*.swf')));
            private var _instPath:String;
            private function onFileOpen(e:Event):void
                _instPath = e.target.nativePath;
                verifyAnimation(e.target.nativePath);
            private function verifyAnimation(path:String):void
                vswfl = new SWFLoader();
                vswfl.addEventListener(Event.COMPLETE,onvSWFComplete);
                vswfl.addEventListener(IOErrorEvent.IO_ERROR,onvSwfLoadError);
                vswfl.load(path);
            private function onvSWFComplete(e:Event):void
               // ok
            private function onvSwfLoadError(e:IOErrorEvent):void
                Alert.show('error10006: This is not a valid b2a file! '+e.text,'error!',4,this);
So when the user opens the application on Windows or Linux, everything is great, but when user has MAC OS X, the code displays error10006: This is not a valid b2a file! Error #2035
i think the code means  URL Not Found or something like that, but WHY only on MAC OS? And how can I fix this???
Thanks for your help in advance
it should work
    Oct 19, 2009 6:20 AM   in reply to bboldi
    You might be facing the same issues I had a while back when I was trying to load PDF files from the local filesystem. In my case, I was using HTMLLoader class, but maybe it's the same with SWFLoader (haven't tried myself). Anyway, in my case the fix was to check for if the user used OS X and if true, prepend "file://" to the url.
    var fileURL:String = File.applicationStorageDirectory.resolvePath("Help Documents/help.pdf").nativePath;
    if(flash.system.Capabilities.os.indexOf("Mac OS") > -1) fileURL = "file://"+fileURL;
    htmlLoader.load( new URLRequest(fileURL) );
    More info here:
    http://playground.deju.nu/2008/07/htmlloader-and-local-pdf-content/
    -Jens
