Has anyone of You encountered comparable problems with the new interface ?
If in customui.cfg a command is defined which Definition comprises more than one action code, then:
Since FM-6 users are happy with the Enhanced Toolbar provided by microtype.com - which I want to make available for FM-9 also (see http://daube.ch/docu/fmaker55.html).
Switching between edit-view and print-view is an action which is performed at least every half hour. The faulty behaviour requires to strictly use either the menu or the assigned ESC sequence.
For example, in customui.cfg the following commands are defined:
*** Borders ON, Text symbols ON, others untouched
<Command EditingView
<ReservedLabel Document &Edit View>
<Definition \x3F1 \x3F2 >
<Mode All>>
*** Borders OFF, Text symbols OFF, Graphics ON, others untouched
<Command PrintingView
<ReservedLabel Document &Print View>
<Definition \x4F1 \x4F2 \x3F8>
<Mode All>>
The toolbar definition for the corresponding buttons contains this code:
<ACTION command="EditingView" tooltip="Edit View: Show Borders and Text Symbols">
<images normal="P_HALFSP_18X18_R.png" rollover="P_HALFSP_18X18_N.png" dark_normal="P_HALFSP_18X18_R_D.png" dark_rollover="P_HALFSP_18X18_N_D.png"/>
</ACTION>
<ACTION command="PrintingView" tooltip="Print View: Hide Borders and Text Symbols; Show Graphics">
<images normal="P_CUSTOMSP_18X18_R.png" rollover="P_CUSTOMSP_18X18_N.png" dark_normal="P_CUSTOMSP_18X18_R_D.png" dark_rollover="P_CUSTOMSP_18X18_N_D.png"/>
</ACTION>
The desired function can be performed by using the menu item or the assigned ESC sequence.
PS: Adobe's bug reporting form an unreasonable demand: such a small input field! no real editing possible to distinguisch text and code...
Klaus Daube
Klaus,
Thanks for reporting this. I haven't tried making modifications to the extent that you show, but based upon other feedback that has come through these forums, it further confirms a number of issues that the new OWL interface has in dealing with expected behaviour by users. I hope that the FM engineering team has figured out how to properly translate prior behaviours by now and that further patches (or the next version of FM based upon the 18-24 month release cycle) will fix these behavioural anomalies.
Hi Klaus,
I tried doing the exact steps you had mentioned - and was able to successfully apply multiple commands through the toolbar icon in FM9 250 build. Multiple actions were executed both through the ESC key sequence and the toolbar.
Could you please try adding this in cmds.cfg under *** File Menu ***
<KeySequence \!noc>
<Definition \x361 \x362 >
<Mode All>>
These 2 commands are to toggle borders and text symbols and they demonstrate that both commands are getting applied via shortcut as well as the toolbar (attaching the toolbar xml file I am using).
If the problem still exists, pls do mail me your .cfg and toolbar file.
Regards,
Amit Agarwal
Hi, Amit,
You use the toggle commands while I (and Shlomo) use the set ON/OFF commands - but the problem seems to be the same.
With your setup (User1.xml and your codes for customui.cfg) I observe the following (FM 9.0p250):
Before execution of menu, ESC sequence or button I have set manuly OFF both Text Symbols and Borders to have a clear situation.
I send You the files by e-mail
IMHO this problem can be circumvented by the method, Amit has found (according to off-line e-mail):
Place the command definition not into customui.cfg, but into cmds.cfg
In this case all three execution methods (menu, esc sequence, button) execute all codes within the command.
Amit accepts this as a bug and will take notice of my bug report (which i entered on Adobe's bug report page.
