COLEEN182
Saving a PDF as a negative image...is that possible?
Oct 26, 2009 9:13 AM
I'm trying to save a PDF from Illustrator as a negative image...like in the print menu in 'Output' you can change the image to Negative.
I need to do this so I can send it to an image setter.
I looked in the help menu and briefly online but I couldn't find anything, please let me know if you know how I can do this or if it isn't possible!
Thanks!
    Oct 26, 2009 9:41 AM   in reply to COLEEN182
    Not that I know of, at least not without a lot of manual adjustments. I don't really understand why you would need that, though. Inverting a plate should be as easy as checking an option in the RIP, so basically using the printer output option is the correct way IMO.
    Mylenium
    Oct 26, 2009 9:54 AM   in reply to COLEEN182
    Send the PDF as 'Print quality'. The image setter should be able to do whatever is needed... no?
