I've built a few Flash forms in Dreamweaver and they only submit with the spacebar key, I can't find how to use the enter key to submit the forms? One is a really simple search field with a submit button, and I think users would likely want to just type and hit enter the way they would with a regular form.
Also the submit button in some forms is in a formgroup (hbox) under a few other fields and it is aligned to the far left, while the other fields are further over. I tried setting a left margin but that only stretched out the button. What's the best way to position it?
This is one of them. Even if I tab over to the button the enter key doesn't submit it. Spacebar does.
<cfform action="" method="post" name="searchform" format="flash" id="searchform" timeout="180" height="250">
<cfformgroup type="tile">
<cfinput type="text" name="searchtext" required="yes" id="searchtext" width="150" message="You must enter text in the search field">
<cfinput type="submit" name="search" value="Search" id="submit" tabindex="0">
</cfformgroup>
</cfform>
Hi Nevesky,
Try this code, it works.
<cfinput
type="text"
name="searchtext"
required="yes"
id="searchtext"
width="150"
field" onKeyDown="if(Key.isDown(Key.ENTER)) {submitForm()}"
</cfformgroup>
</cfform>North America
Asia Pacific
