mariam91
Directional Blur Affects Position of Clip?
Oct 31, 2009 3:54 AM
Hi guys,
When I apply the directional blur to a clip and adjust the amount, the clip moves to different positions depending on the angle and amount set. When I bring the amount back to '0' it goes back to its original position. I've seen the same thing happen at times when I use the gaussian blur but I haven't been able to reproduce that effect today, although the issue came up yesterday, and so I'm not sure that what's happening with the directional blur should be happening. I'm running Premiere Pro CS4 on a Mac. Sequence settings are the HDV 720p preset. I'd be happy to take screen shots if need be. I want to know if it's normal/if not how to get rid of it/how to get rid of it regardless? I've used other NLEs with the same effect and none of them had this issue.
Thanks in advance.
    Oct 31, 2009 9:29 AM   in reply to mariam91
    Same thing happens for me with DV media.  I don't know if this is a bug or SOP, as I never use this effect.
    Nov 23, 2009 12:19 PM   in reply to mariam91
    Most certainly looks like a bug to me.
    WORKAROUNDS:
    • As Mariam said- if there are multiple effects, move the Blur down or probably UP (in Effect Controls) to fix the problem
      (As you probably know, Premiere processes each effect applied to a clip  one after the other)
    • If you only have motion blur, I think you'll find the problem is caused by having more than one Blue keyframe in a row with a value of zero. Try changing them to 0.1 for probably no perceivable difference.
    May 17, 2013 4:25 PM   in reply to mariam91
    Adobe? will you ever fix this bug? we've paid for you buggy software...
