Fireworks unlock keyboard shortcut
Nov 2, 2009 8:17 AM
I'm aware of the "Lock Selection" keyboard shortcut (Ctrl + Alt + L). Is there an accompanying "Unlock all" keyboard shortcut, like, I believe, Photoshop has? The only way I know how to unlock something is to click the padlock icon from the Layers panel.
    Nov 2, 2009 8:40 AM   in reply to pup500
    If there isn't a shortcut in the default set, you can always go into Keyboard Shortcuts and create one.
    Nov 2, 2009 9:46 PM   in reply to pup500
    I can't find an "Unlock all" option, too.
    The closest thing I was able to find are two commands by Aaron Beall:
    ( See here: http://fireworks.abeall.com/extensions/commands/ )
    This is maybe not exactly what you're searching for, but maybe close...
    The first command will lock *all* unselected objects in the PNG file. The second will *unlock* all of the previously locked objects. After a bit of trial and error, this will maybe help you. If not, then maybe some other Fireworks guru will help you better than me in finding your solution... (Basically, you need to find all locked objects and unlock them with one command -- I don't think there's an integrated shortcut in Fireworks for that, but maybe such a command can be created (if it isn't already) by some Fireworks developer.)
    Btw, I have also found (after some search) a modified version of Aaron's commands:
    http://wearemortensen.com/blog/archive/fireworks-commands-isolate/
    You may want to check it, too...
    Nov 2, 2009 10:02 PM   in reply to pup500
    Hmm, I guess I was thinking of the "show all" command, which shows all previously hidden elements.
    Michel's right, your best bet seems to be one of Aaron's commands.
    Nov 2, 2009 10:09 PM   in reply to John Dunning
    Wow, The John Dunning!
    Just joking, nice to see you around! (I guess I've been away from these forums for some time and closer to testing and crashing Fireworks... 'guess I should catch up a bit here, too;-)
    Nov 3, 2009 10:56 AM   in reply to pup500
    I am sure such an extension (unlock all objects) can ve created for Fireworks. Unfortunately, I am not that good in programming, but more into design, so I cannot help... :-(
    Glad that I helped a little bit, at least, giving you some direction!
    Nov 3, 2009 10:34 PM   in reply to pup500
    In C:\Program Files\Adobe\Adobe Fireworks CS4\Configuration\Commands, create a file called "Unlock All.jsf".  Open the file and paste this in:
    fw.getDocumentDOM().setElementLocked(-1, -1, -1, false, true, false);
    Save it, then give it a shortcut in Keyboard Shortcuts.
    You've just created your first Fireworks extension!
    Nov 4, 2009 4:21 AM   in reply to John Dunning
    John, that's amazing! One-line command does all that is needed!
    (Here it is attached, as ready-to-use .jsf file (inside ZIP archive), for the convenience of anyone else that would like to download the command right away and start using it.)
    I am still amazed how simple it looks once you have created the code! Hats off!
    Nov 4, 2009 5:53 AM   in reply to pup500
    Yes, John is the Master!
    Nov 4, 2009 12:32 PM   in reply to Michel Bozgounov
    Well, hats off to the Fireworks API.  Some things, it makes very easy.  Others, not so much...
