I am using the Cairngorm Popup 1.0 library and have defined a popup like:
<popup:PopUpWrapper id="newObjectClass" center="true" modal="true"
closed="newObjectClassClosedHandler(event)">
<uid:NewObjectDialog id="newObjectDialog"/>
</popup:PopUpWrapper>
However when I try to compile this I get an error like:
[ERROR] /home/k/dev/src/flex-application/src/main/flex/Editor.mxml:[142,-1] Event type 'com.adobe.popup:PopUpEvent' is unavailable.
If I removing the 'closed' attribute on the PopUpWrapper compilation succeeds.
When I look at the library's PopUpBase I see that the following is declared:
[Event(name="closed",type="com.adobe.popup.PopUpEvent")]
I cannot find the class com.adobe.popup.PopUpEvent although I do see that the library includes class com.adobe.cairngorm.popup.PopUpEvent. Is the Event declaration in PopUpBase incorrect or am I missing something?
The fix for that bug is in trunk.
Thanks, Alex. Can you tell me when I might expect a release containing
the fix?
