Greetings everyone,
I'm trying to set up a Watched Folder endpoint, but I don't want to specify a file type. I want to use this watched folder in the following way:
1) Drag a FOLDER to the watched folder
2) Watched Folder picks up the entire folder
3) Orchestration launches to process the folder (i.e. read documents contained within).
So how do I set up the watched folder to do this? Furthermore, once it's set up correctly, what sort of input would it be in the orchestration? A list of documents? What would child folders be stored as? For example:
Root Folder
|---> myFile.pdf
|---> More Folder
|---> mySecondFile.pdf
|---> myFinalFile.pdf
Would this be stored in the orchestration as:
<list>
<myFile.pdf>
<list>
<mySecondFile.pdf>
<myFinalFile.pdf>
</list>
</list>
Any quick answer would be greatly appreciated.
Thank you,
Alex Kloft
Views
Total Likes
Use * for the input mapping and it'll put the folder content in a input list or map of documents.
Jasmin
I tried that and it seems to not look in the child folders...do I have something set up incorrectly?
Currently I have:
AdminUI:
input parameter mapping:
Variable: *.*
Orchestration:
mInputFolder type: map subtype: document input and required
should I change the subtype to something else so it doesn't try to treat the child folders as a document?
Views
Total Likes
Sorry I missed the sub folder structure.
I think it'll only go down one level, so the subfolders won't work.
Jasmin
Views
Total Likes
