Hi I am about to do my ACE exam for ID
So i have been studying away - and am not happy with the 'preseve image dimension' option
Here is a practice question from the adobe site (with supplied answer)
4.1 Given a scenario, determine the best settings for choosing and placing an image
You want to replace an image from a selected frame. The new image is larger than the original
image. You want the new image to be imported at the same scaling percentage as the original.
What should you do?
A. hold down Shift as you click the Relink button in the Links panel
B. hold down Option/Alt as you click the Update button in the Links panel
C. before replacing the image, deselect Preserve Image Dimensions When Relinking in the
File Handling pane of the Preferences dialog box
D. before replacing the image, select Preserve Image Dimensions When Relinking in the File
Correct answer: C
BUT it says this in the help file
When you relink to replace one graphic with a different source file, you can keep the image dimensions of the file that’s being replaced, or you can display the incoming file in its actual dimensions.
Choose Edit > Preferences > File Handling (Windows) or InDesign > Preferences > File Handling (Mac OS).
Choose Preserve Image Dimensions When Relinking if you want images to appear at the same size as the images they’re replacing. Deselect this option to have relinked images appear at their actual size
Is this a contradiction or am i being thick
I would agree that the correct answer is C, and further, I'd say the help file is incorrect (and probably should be reported to Bob Bringhurst). The behaviors you should see are either maintaining the image dimensions (NOT scaling percentage) or maintaining the scaling percentage that has been applied in the frame. If you try it you'll see that's how it actually works.
The only time an image would be placed at 100% during a re-link is if the one it is repalcing is also at 100%.
Peter
Sorry Peter
I think I must have hit it by mistake
But just experimented with it on 6.04
I have image 210x297
I replace this with preserve image dimensions ON -new image is 210x1776
I replace this with preserve image dimensions OFF -new image is 25.013x211.552 --- which is the same size as if imported into a new frame
Doesnt this make the help file correct and the adobe practice exam wrong ?
I assume the original to be the image that is being replaced
What should you do?
Correct answer: C
Did you scale the first image in your second experiment? The new one should come in at the same SCALE, so if you scaled the original to 50% the repalcement should also be at 50% of its actual size.
I've just done this test again for the second time to reconfirm that this is the way it works. You might want to try it for yourself. Place an image at 100% for reference, then make two copies, one at an enlarged scale and one at a reduced scale. Relink all three to the same new image and check the scaling percentages. They should be the same as the original images when "Preserve Image Dimensions When Relinking" is not selected.
You should see the same behavior if you select the frame and choose Place instead of relinking.
Peter
I cant get this to work
When I replace the three images with the same file, they all stay exactly as they were regardless of whether preserve image dimensions is on or off
What I have noticed is that if I replace one image with another
with preserve dimensions on the new image has the same width as the the replaced one
with it off the new image comes in with he same scaling as the replaced one had
any ideas
I don't understand what you mean...
Right, that's what's supposed to happen, and it NOT what the help says.
My eps image was at 100%. I had the Preserve Image Dimensions checked on. I was given a new eps with a minor change. I assumed the relinking would also be at 100%. But in came in at 105%. If the Preserve Image is on then whether I put my original at 95% or 100% that is what my relinked image should also come in at. But it did not. Does any one know what is going on. I have had this happen a few other times since I have been using InDesign CS4.
North America
Asia Pacific
