Peter Spier
Troubleshooting 101: Export to .idml or .inx to clear file corruption
Apr 3, 2012 10:23 PM
Sometimes a particular InDesign file may behave badly (if all your files are doing strange things, see Replace, or "trash" your InDesign preferences ). In such cases the first thing to try is export to .inx if you have CS, CS2 or CS3(InDesign Interchange format) by selecting File > Export… and choosing .inx from the file type dropdown, or if you have CS5 or later export to .idml. The resulting file should then be opened in ID and saved as a NEW .indd file.
Interchange format was set up to allow users to open files in a version of ID one release earlier (minus, of course, new features) than the one in which they were created. It reduces the file to the bare minimum of information needed to recreate the layout, and as a side effect it often strips out minor corruption that will cause strange behavior but is not bad enough to prevent the file from opening. Other things Interchange Format can help with are removal of stubborn unused swatches and references to missing plugins.
The  .idml (InDesign Markup) format was introduced in CS4  and in that version you have your choice (.inx is listed as CS3 interchange) and is the replacement for .inx going forward. My non-scientific intuition says that .idml is slighlty less effective than .inx at solving problems, so I would opt for .inx in CS4 as my first choice, but I also would not dismiss .idml out of hand if I suspect document corruption.
Updated 12/14/2011
Message was edited by: Peter Spier
    Community Member
    Dec 17, 2009 7:28 AM   in reply to Peter Spier
    This was extremely helpful. I crashed about a dozen times after updating from ID3 to ID4 before discovering this fix. I still don't exactly understand why this worked—I'm dim that way—but it did.
    Apr 1, 2010 11:35 AM   in reply to Peter Spier
    Thanks. Worked for me also. CS3 asking for missing CS2 plugins.
    Jul 6, 2010 12:23 PM   in reply to Peter Spier
    That worked. Thanks so much. You just saved me an unbelievable amount of work.
    Community Member
    Sep 1, 2010 2:09 PM   in reply to Peter Spier
    oh dear god, thanks a lot, it fixed all the problems i had with a CS4 book opened in CS5, for an unknown reason the document had locked anchored object that was making CS5 crash everything i was trying to touch the anchor, the idml file fixed the problem, i can now choose to unlock the graphic (this action was grayed out before)
    plus it solved a problem i had with the text box inset option, couldnt change the right and left inset... now i can..
    just sad that it cannot auto-convert itself properly..
    Dec 22, 2010 4:36 PM   in reply to Peter Spier
    Hi, I'm not seeing this option in CS5 under File>Export. Am I missing something?
    Community Professional
    Dec 22, 2010 4:51 PM   in reply to la jessica
    Yup...in CS5 it's export to IDML.
    Bob
    Community Member
    Dec 22, 2010 5:21 PM   in reply to Peter Spier
    I did not see that - thanks for pointing it out.
    Community Member
    Mar 5, 2011 4:43 AM   in reply to Peter Spier
    My CS3 file went from 2mb to 1,7mb in CS5. Sweet
    Apr 12, 2011 9:28 AM   in reply to Peter Spier
    Hi! I did this as you mentioned, and the file became much much smaller! So right now I can just continue my work using the new indd file is that right?
    Community Member
    Apr 12, 2011 9:38 AM   in reply to Reneeong
    Yes.
    BTW: I have had no crashing problems since updating to CS5.
    Community Member
    Apr 12, 2011 9:40 AM   in reply to MUJason
    okay thank you very much!
    May 4, 2011 2:43 PM   in reply to Peter Spier
    I have several documents that I export to PDF using data merge. All of the documents have been exporting very nicely each and every time I use them with the exception of one. Today when I tried to export it, CS5 crashed. So I cut and pasted and made a new document, thinking that might work, but it still crashed. So I tried exporting the document as a IDML. I opened the IDML file and tried to export it using the data merge to PDF and it still crashed. Any ideas on what else I might try, besides redoing then entire 23 page document?
    Community Member
    May 4, 2011 3:08 PM   in reply to chris@eeap.net
    To my knowledge, (through CS4) you cannot Data Merge to pdf, but rather create a new file. I have exported to pdf immedialtely after creating a merged doc, but at that point it is not saved.
    Are there images contained within the merge doc? I would look at those first.
    Hunt and conquer method - Start eliminating half the document pages or elements at a time.
    Community Member
    May 4, 2011 3:12 PM   in reply to Peter Spier
    I am using CS5 and I do have graphics throughout the document. I will try eliminating the graphics and see what happens. I just find it wierd that I have been using this same document for the past 6 months, as well as the other documents, and yet today it decides to give me problems. @@
    Thank you for the quick response.
    Community Member
    May 4, 2011 3:13 PM   in reply to Peter Spier
    Thanks. I will do that tomorrow. I have some other projects that I need to work on for work right now. But I did say I was using CS5 and I am using Vista as my OS.
    Jul 18, 2011 8:31 AM   in reply to Peter Spier
    Yep.  Worked for me.  Cheers
    Community Member
    Aug 10, 2011 2:26 PM   in reply to Peter Spier
    How about if you are working on a book?  Export is not
    an option once you are in InDesign screen with the book file open but none of the component files open..  I have to export all 11 documents it is composed of?
    Using CS5.    That would be File>Export and in that window, Save As Type> in popdown choose IDML (index design markup language), right?  Then I link the new files to the book and delete the others????
    Thanks for your help.
    Community Member
    Aug 10, 2011 2:54 PM   in reply to Peter Spier
    wow 2 min to get an answer, very impressive!  It's a TOC problem
    , won't recognize the headings in the section its in.  Sometimes erases all the other text except the TOC-- like maybe I did something when adjusting the frames and it thinks the whole document is part of the toc.  (it used to work just fine)   Someone suggested maybe minor corruption, so I was looking into your proposed solution..  I just had the frames idea in the past few min.
    .   Where should I post this and what would u suggest as a heading
    btw is there a seach function on this site?  can't find one
Bookmarked By (1)
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
