PC freezes with CS4 when editing imported image in imported 1.5 project
Nov 18, 2009 11:11 PM
I am new to CS4.  I have imported a PPro 1.5 project into CS4.  Initially, I tried to launch the CS4 project by double clicking the 1.5 project.  The 1.5 project was converted to CS4, however, when the CS4 project opened, there was not timeline.  I deleted the CS4 project, then opened CS4 as a new project selecting the corresponding 1.5 sequence.  A timeline was created.  I then imported the 1.5 project.  However, this time there was no indication of a project conversion.  I cut the project where I wanted to insert three jpg photos that were dragged from the project area into the timeline.  I used the 'Change to Color' Effect to harmonize the color in the three photos.  Each time I tried the effect my PC froze requiring a restart.
What am I doing wrong or is there an error in the steps I have taken?
    Nov 19, 2009 2:34 AM   in reply to John Ratard
    function(){return A.apply(null,[this].concat($A(arguments)))}
    That is easily remedied by double clicking on the sequence in the project panel.
    Can you give details. Look here and answer the 16 questions at the end of the Wiki article. Some suggestions
    Nov 19, 2009 11:35 AM   in reply to John Ratard
    The hardware is no problem, great setup. You have the 9.11 ATI drivers?
    What is your source material? DV? What is the size of the stills? Any more details on your project and sequence settings that may be relevant?
    Nov 19, 2009 12:01 PM   in reply to Harm Millaard
    Since the stated issue is now with the still images and the Effect added, pay particular attention to Harm's request for info on those. Here, more is definitely better. Answers to the other questions will likely prove useful too.
    PS - Harm hit the Imported Project's Timeline display - Dbl-click on the Sequence in the Project Panel, after you have opened the necessary Bins.
    Nov 20, 2009 12:56 AM   in reply to John Ratard
    John,
    It may be time consuming, I mention it because I have in the past experienced a similar situation when importing a project from a previous version into a later version, but it may be necessary to go through your whole timeline and identify each and every transition and effect that requires rendering in order to identify which of those did not transfer correctly from 1.5 to 4.2. Once you have identified which transition or effect may be causing this issue, you have to delete these and replace them with the 'same' effect from 4.2. In my case it was with effects from a plug-in.
    Just to be sure that your source material is using the correct codec (AVI is just a wrapper), check with GSpot that you are indeed using DV AVI type2. It may be possible that the codec is DV AVI type1, in which case that also can lead to trouble. You will then need to convert type1 into type2. DVConverter from GV/Canopus comes to mind.
    Nov 20, 2009 12:20 PM   in reply to John Ratard
    John,
    The freeware utility, G-Spot, will help determine the CODEC's used by your telecine progarm.
    As you found out, Unsharp Mask is a much better Effect, than any flavor of Sharpen. I know that the name doesn't bely its use, but you got it right.
    Now, when Importing Pr 6.5 Projects into PrPro 2.0, I actually got dialog messages on Transitions that would not come into the newer program. Adobe even provided me with the exact name of the Transition, and the TimeCode for where it was used. This was very useful, as a couple were no longer available in PrPro, and some were 3rd party Transitions. I took notes, went to those TimeCodes and just added the proper Transitions from those in PrPro. There were fortunately, no Effects that were 3rd pary, or were no longer available in PrPro 2.0, so I do not know how the program might, or might not, have handled those. I'd think that PrPro would have done similar with Effects, but I might be totally wrong.
    Just some thoughts,
    Nov 21, 2009 1:36 AM   in reply to John Ratard
    John,
    Am I correct in assuming that if you delete the 'change to color' effect, everything works as it should? If so, reintroduce this again in a single place, does it still work?
    Nov 22, 2009 12:57 PM   in reply to John Ratard
    John,
    A freeze that requires a cold reboot is serious and not always an application problem. Had you been able to do a warm reboot I would have expected a software problem, but a cold reboot is pretty rare these days, unless there is a hardware problem or conflict. Can you give us a detailed list of your hardware, OS and most telling give us as attachments and screenshots the info requested in the second link here: Some suggestions
    Especially the info from DXDIAG and Process Explorer can be very informative and you may have a difficult time using the camera icon for screenshots since the latest Jive update. It mimics Adobe updates: When it ain't broken, we'll break it.
    Nov 22, 2009 1:00 PM   in reply to Harm Millaard
    Along with Harm's suggestions, this ARTICLE might help you find "clues," as to what is happening, when your system locks up, or crashes.
    Dec 2, 2009 2:30 AM   in reply to John Ratard
    John,
    Can you attach a screenshot from Process Explorer and the DXDIAG.TXT file. Instructions can be found in the second link included here: Some suggestions
    Dec 2, 2009 4:43 AM   in reply to Harm Millaard
    John,
    I googled the error messg you got in your event log;  Got an answer like this below:
    Source/Error #: Disk / error 51
    Message: An error was detected on device \Device\Harddisk3\DR3 during a paging operation.
    Notes: This error indicates an I/O error during a hard page fault.   Discussed in KBs 304415 and 305547.
    I've built a couple computers but I'm no expert.  I kind of thought when I first read about your problems that the crashing might be a memory page swapping problem though I couldn't tell you why ...maybe the specs on your machine being so fast and powerful and the size of your AVI..and the fact it was freezing.
    I don't think this has anything at all to do with a hard drive driver, but latency between a memory page swap and getting through to your hard drive to finish the write to the drive.
    Further googling about the error message gave me the following info: but it seems you'd have to extract what is applicable to your situation.
    It may be that you have two variables happening at the same time in comparison to what you accomplished before with 1.5 ?
    1) a new machine
    2) a new program (CS4)
    I thought the reference below to using the local (boot) disk (instead of Disk 04) might be interesting to try ??
    follows is the info from googling the ms publications kb 304415 and 305547:
    Your computer stops responding (hangs) or has slow response times. This can indicate that there is a high latency to the pagefile, and this may be accompanied by events in the System Log such as:
    Event ID: 51
    Event Type: Warning
    Event Source: Disk
    Description: An error was detected on device \Device\Harddisk0\DR0 during a paging operation.
    Event ID: 11
    Source: %HBA_DRIVER_NAME%
    Description: The driver detected a controller error on Device\ScsiPort0.
    Event ID: 9
    Description: The device, \Device\ScsiPort0, did not respond within the timeout period.
    If the preceding error messages are in the System Log, it indicates that Windows was trying to access a disk and there was a problem. If the disk that is referenced is on the SAN, it could indicate a latency issue. If an Event ID 51 is shown, this indicates that Memory Manager was attempting to copy data to or from memory and had a problem. Another indicator of pagefile latency issues is if the Windows server has a system failure, and either of the following error messages are displayed on a blue screen:
    0x00000050 PAGE_FAULT_IN_NONPAGED_AREA
    or
    0x0000000A IRQL_NOT_LESS_OR_EQUAL
    A possible resolution is to place the pagefile on the host's local hard disk. Windows needs reliable access to the pagefile as data is paged in or out of memory. Having the pagefile local to the host guarantees that access is not influenced by other devices and hosts on the SAN.
    Note If the pagefile is not on the same partition as the boot partition (typically c:\Windows or c:\WINNT), the creation of a Memory.dmp file will not occur. A Memory.dmp file is used for troubleshooting a Windows computer that has a STOP error. For information about how to configure your computer for a crashdump, see Windows Help.
    There are several ways to resolve the preceding problems. The first method is to try and correlate the time with any events that are occurring on the SAN. For example, it HostA was doing a large copy operation and HostB reports the Error 9s, it may imply that proper LUN management is not in place. Another example is if HostB produces errors whenever HostA is rebooted. This may indicate that FC-AL is being used and HostB is being affected by a Loop Initialization Primitive (LIP) sequences from HostA. These can often be corrected by re-configuring the SAN, and this requires the assistance of the hardware vendor. Any type of latency issues might be resolved by placing pagefile on the Windows server's local hard disk, but again, this disables the creation of a memory dump. A key point to understand is that the hardware vendor of the SAN will have the most information about the proper configuration, and must be the first point of contact for all configuration questions and concerns.
    Dec 2, 2009 12:01 PM   in reply to robodog1
    John,
    Me again...was thinking after sending last mssg...again I am not an expert...so take with grain of salt...
    years ago I used to have to deal with twain and peripheral devices (scanners) issues...and (I'm thinking maybe this was with Windows 95 ?) and scsi devices (virtual in my case) and ....it was always worth checking for IRQ conflicts and DMA (dynamic memory addresses ) assigned to certain hardware elements of a system...  Might be worth checking out your computer to see if you have any conflicts and if any of your hardware manufacturers suggest anything specific ??
    Rod
    Dec 3, 2009 11:15 AM   in reply to John Ratard
    John,
    Is any of the media, linked in your Project, on that external? What is the connection, USB, FW-400, FW-800 or eSATA?
    Software for the WD should not be needed. It should be mostly utilities and maybe some form of backup software. I found that the Maxtor utilities and their drivers, could fritz up things with their USB externals.
    Now, I use FW-800's and many of these contain all of my Projects, including the Assets and Scratch Disks. When I boot up, there IS a lot of activity, as Windows checks these externals, and does things like get their info into Windows Explorer. The light flash a bunch and for several moments. This is normal. In my case, each external has a unique drive letter assigned in the OS of each computer that they might be plugged into. This is some of the "stuff" that the OS is looking at. By setting that drive letter assignment, each external is ALWAYS seen with that drive letter. Must be set in the OS of each computer.
    Going back, I tried using USB's to edit to/from. I found two problems with the externals of those days: they were slow as could be, and I got Delayed Write Errors, plus Read/Write issues with these. I now use them JUST for archival storage of media Assets, and will Copy these over to the internals, or to my FW-800 externals, when I go to edit. I do not link to any of the Assets on these USB externals - never. Same thing for my NAS drive. I store, but Copy, before editing.
    Dec 3, 2009 1:17 PM   in reply to John Ratard
    The WS Pro only has 1394A and the A means FW400. 1394B is FW800, but none of the P6T range have that on board AFAIK.
    Dec 3, 2009 2:50 PM   in reply to John Ratard
    OK, no vestige of the Project is on the external. Any necessary media has been Copied over to the internals. I'd disconnect the WD external, just as a test. It should have no influence, but then we could rule it out completely.
    PS - back when, I never had a single issue with a FW-400 external, except for the slow connection.
