Nov 26, 2009 5:33 PM
Pixie Dust
Like (0)
Happy Holidays
JET
Sorry.
No edit button for the initial post?
The required Faux Halftone script is here.
Also, after creating the Object Mosaic in step 8, get the Magic Wand tool and click one of the white tiles to select similar colors. Then Delete. That will reduce the number of paths that have to be evaluated for grayscale value by the script and save some time.
JET
Thank you Jet for this great post.
Happy Holidays to you too!
Hans
James,
As far as I remember it is hidden away under Actions to the right (and only accessible until the first post which locks it because it is an answer to it).
James
Thank you, great script, mind blowing....!
Delightful! Thank you, and Happy Holidays to you as well.
Peter
A very nice tutorial, thanks! Is there a CS4 equivalent to the instructions in step 8 (Filter>Create>Object Mosaic)?
Object>Create Object Mosaic.
Always helpful to do a little menu exploration. Sometimes you find what you're looking for just by looking for it.
Quite right, I overlooked it, thanks!
This looks amazing.
Would it work in CS? I really should just upgrade but after reading everyones thoughts about CS3 & 4 I'm a little hesitant.
Can't say for sure, but probably. Try it. You won't break anything.
JET
JET (James?),
I've followed the instructions, just a quick question though. Just file doesn't seem to like .jsx Could I rename it to .js instead?
Try it. I'm not sure which version of Illustrator started understanding the .jsx extension.
JET
CS2 will use either .js or .jsx. I have an earlier folder of the JETPathScripts in my CS2 scripts which are all with a .js extension. For the original CS you will need to use the .js extension.
Awesome stuff.
Changed the file type to .js
Followed your instructions to the letter, added some bits along the way
And it works (not that I was doubting you).
Thank you so very much JET, Your hard work is very much appreciated.
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
