Revision: 12548
Revision: 12548
Author: mmoreart@adobe.com
Date: 2009-12-04 12:36:58 -0800 (Fri, 04 Dec 2009)
Log Message:
Fix FB-16879: FDB print # no longer works. You're welcome Alex ![]()
It's tricky to handle "print #1234" now, because we now use asc's parser to parse the expression ("#1234"), and that is not a legal ActionScript expression. To hack around this, we now detect "#" followed by one or more digits, but only at the very beginning of the expression. If we see that, we replace it with "$obj(1234)". $obj() is a new pseudofunction handled by the FDB, which evaluates to the object with id 1234.
This means you can do any of these:
print #1234
print #1234.
print #1234.toString()
print $obj(1234)
print someFunction($obj(1234))
but you can't use the "#" syntax anywhere except at the very beginning of an expression -- this won't work:
print someFunction(#1234)
Ticket Links:
http://bugs.adobe.com/jira/browse/FB-16879
Modified Paths:
flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concret e/PlayerSession.java
flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/express ion/ASTBuilder.java
North America
Asia Pacific
