Dec 8, 2009 9:03 AM
Early and late binding workflows in ICC based color management
Like (0)
Hi all!
I'm a graphicdesign student at Reading Uni in the UK, and I'm writing my BAdissertation on early and late binding workflows in ICC based colormanagement for print production. I'm intending to write to a graphicdesigner audience from a designer's point of view. Please do commenthere if you have anything to say on this topic, or you can point me tothe right direction. I'm also looking for studios where I could conductmy case studies who employ early, medium or late binding workflows.
Thank you.
We have had some lively discussions regarding late binding, one in particular comes to mind:
http://forums.adobe.com/thread/477312
The crux of the matter is the conversion of RGB to CMYK, and when it occurs – at design stage, or prepress stage. Here are some hurdles to overcome:
1. There are many different RGB color spaces, of various shapes and sizes. It makes things confusing.
2. There are many different CMYK color spaces, of various shapes and sizes. It makes things confusing.
3. CMYK is usually a much smaller color gamut than a source RGB gamut. This can be difficult to explain sometimes. If a designer loves the source RGB, the CMYK destination can oftentimes be a letdown.
4. Color management works as long as everyone in the production line does his or her part. It is easy to adhere to a good workflow, but it is also very easy not to. And it only takes one user to break the chain.
5. Good proofing is essential. This includes soft proofing and paper proofs. Time, money and effort are necessary to make good proofs. It may be tempting to cut corners, but it's much better to invest in a good proof than be disappointed in a print result.
Thank you Rick for your answer. There's one question in particular I haven't seen mentioned anywhere before. For late binding workflows they mention RGB color spaces as workingspace at all discussions. But since they use RGB working spaces because of their larger gamout sizes, why don't they use LAB working spaces as the gamout of that is supposed to contain all visible colours and device independent?
That is a valid question.
I personally like Lab but by and large in the design community I believe it's not as user friendly, certainly not in Photoshop.
But it goes beyond that. Since there is no Lab device, no image starts out as Lab. The initial photo image capture has to be some sort of RGB, whether it's a digital camera or scanner that's used.
Not only that, the monitor is the medium for viewing files and monitors are RGB devices. Lab is monstrously huge. If you design in Lab there is great potential for creating colors way beyond the monitor's gamut (however the same can be said for large RGB spaces like ProPhoto).
Also, placing RGB images and converting to CMYK on output from InDesign is a workflow that is increasing in popularity. I don't believe you can convert these images to Lab when outputting from InDesign (I could be wrong about that). On the other hand preserving Lab color in output is possible, and technically it is the proper color space for Pantone spot colors.
Lab is extremely useful for measuring colors in the real world. For example, if you have a previously printed sample there's no way to know the CMYK values. But you can always use a spectrophotometer to measure the color, and then the color is defined. Once defined it can be mapped to RGB or CMYK.
Device independence and a large gamut are not necessarily and advantage when you are editing because you still have to consider the dependence and narrow gamut of the destination device.
If you are making edits in Lab based on visual feedback, the Lab preview is in your monitor's RGB space—you are not seeing a larger gamut than your monitor can produce. To force the preview into some other space you would need to setup a custom Proof Setup and turn on Proof Colors.
If you are editing by the numbers rather than preview, you still need to look at the destination profile (CMYK?) numbers because Lab numbers being device independent have no meaning relative to output. You can choose out-of-gamut colors, but they ultimately get forced back into the destination device's gamut.
The advantage of an RGB editing space is that it is transferable—we both can work in the same space (AdobeRGB?) by embedding the file with the AdobeRGB profile. If we share Lab files they can't be profiled and we end up previewing the file in different spaces.
Actually two users can share Lab files and see consistent color provided the monitors are very accurately calibrated and profiled. Monitor calibration devices are based on Lab readings so good color communication using Lab files is possible.
Likewise two users could share an Adobe RGB file and if one of the monitors is inaccurate, the color is still not communicated properly. So the RGB color space does not create an advantage over Lab in that respect.
But the problem remains, as pointed out that Lab transcends any monitor. There is a chance that the file has colors that you don't see. One way I know of to check for this in Photoshop. Go to View: Proof Setup. By Device to Simulate select the monitor profile. Rendering Absolute. Hit enter, then View: Gamut Warning. This shows the file colors that don't exist on the display.
However there is another big problem using Lab images pertaining to InDesign. InDesign has no Lab flattener color space. I see problems if a Lab image interacts with transparency. That may be enough reason to steer clear of Lab images.
But the parties would need to agree on the monitor settings. If I calibrate and profile to 5000K/1.8 gamma and you calibrate and profile to 6500K/2.2 gamma, the Lab color will display differently in the two monitor RGB spaces even if the calibrations and profiling are accurate.
The point of embedding RGB display profiles like AdobeRGB, sRGB, or ProPhoto is that you can share files without agreeing on a monitor calibration spec and its accompanying monitor profile.
I guess I'm not understanding right. I thought Lab colors were more or less fixed. For example L25 a15 b-68 (Pantone 286 C) is what it is (at least in the proper viewing and lighting conditions).
If a Lab color display is untrue, it either means the color is beyond the display gamut, or the monitor is not calibrated and profiled properly.
Your example of two monitors, one calibrated to 5000K Gamma 1.8, the other 6500K Gamma 2.2 probably would display the same Lab image differently. But wouldn't it also display the same tagged RGB differently? My thinking is that one of the monitors is more accurate than the other. Or maybe one is more accurate in one part of the spectrum, the other is more accurate in another part of the spectrum.
A tagged RGB image still relies on Lab color as an intermediary for display purposes, so there could still be disparity between the two displays. The difference with a Lab image is the source color is already committed. What remains uncommitted is the destination color, CMYK in the instance of print design. I would think two users with different accurate calibrations could still soft proof Lab color in the same destination CMYK and maintain good color communication.
Spot colors have Lab definitions too, and a user can soft proof a spot color as long as it in within the display gamut.
Not trying to be disagreeable, I know you are knowledgeable in this area. Maybe my logic is wrong?
Lab is device independent so it can't be displayed or printed.
If you want to print a Lab color on a CMYK press it needs to be converted into a CMYK color somewhere in the workflow. Likewise if you want to display it on an RGB display there needs to be a conversion into an RGB space—it's like CMYK color, which also needs to get converted to RGB for display.
Lab is excellent for representing solid ink colors, but you are not printing Lab 25|15|68 you print the Pantone ink 286 at 100%. Lab simply acts as an abstract color space to make the translation of the Pantone 286 to RGB for display or to CMYK for CMYK printing.
In Photoshop, if you look at a Lab color that's outside the RGB gamut, I think it's pretty obvious the conversion of Lab to RGB for display is into the monitor profile and not your working RGB space. Fill a Lab doc with an out-of-gamut color like Lab 100|-95|60 and soft proof it with your monitor profile as the device and the color doesn't change, but it does if you choose other RGB spaces.
There could be a disparity in practice (the monitor profile is wrong) but not in theory. The point of the profile is to get your file's display from your monitor RGB space into another known RGB space. So if we both have monitor profiles which are perfect representations of our respective displays, then the profiled RGB file can be accurately translated into the same white point, gamma, and primaries—6500|2.2|Adobe(1998) in the case of AdobeRGB.
If Lab could be used to display color consistently on any calibrated display we'd all be using it and there wouldn't be any use for embedding RGB display profiles.
you can start your paper off by saying that with all the advancements in software technology the print indistry is still processing garbage. Enough said.
I've been involved in color reproduction for just over 30 years, having started out doing indirect separations on cameras and enlargers - just about as early-bound a workflow as is imaginable. Over the past several years - since the introduction of InDesign CS, more or less - I've been involved in numerous high-quality book projects which were done with an extreme late binding workflow - i.e., all image data was maintained in RGB until final, deliverable PDFs (or, in a couple of unfortunate cases, packaged native InDesign files - at the insistence of the prepress or print provider) were made.
While this sort of workflow is certainly not foolproof, it can and DOES work in my experience. The results on all of these projects were absolutely terrific. Our monitors matched our inkjet proofs, our inkjet proofs matched those the prepress house made, and the final printed product matched all of them. When I say "matched," I don't necessarily mean they were perfect, but they were very close - and an order of magnitude (or two) closer than the best color proofing systems we used "back in the day."
One of the publishers with whom we did a project always sent a person to the press run in order to "tweak" color to its best. On the last project they did (which was their first using the late bound process), that person reported having next to nothing to do. I have a feeling that they won't send anyone on their next book...
As has been pointed out, much of this success is dependent on having really, really good profiles - for the final press condition, and any proofing devices you may be using, including monitors. Creating good profiles is not a trivial exercise, but there are a number of prepress houses and dedicated service providers that can create excellent profiles. Besides that, understanding how InDesign deals with color management is key. (Based on my reading of this forum, I'd rely on Rob Day's advice in particular.)
As an "old fart" who used to doubt that a late bound process could ever be as good as an early bound one, I hereby testify that it CAN be...
Thank you all for the replies, there are several very substantial points that have been made. Is there anybody who does adit in LAB?
If your goal is late binding color management then editing in Lab would not make sense because you can't profile Lab—you wouldn't be able to save your Lab file and include a profile, which is essential for cm at output.
I don't think I understand your point, Rob. If I place an RGB image in an InDesign document, and ask for CMYK output, at print/export time InDesign converts the RGB data to my desired CMYK space - using either embedded or assumed ICC profile data for the RGB image, and the targeted CMYK profile. I think it does this essentially by converting it from RGB to Lab, and then Lab to CMYK. If I place an Lab-based image into InDesign, and ask for CMYK output, it seems to me that the application simply doesn't need to do as complex a transformation.
I've just tried this with a few images - RGB and Lab versions side-by-side in an InDesign document, and the output seems pretty much the same - at least to the casual observer.
Can you please explain your thinking a bit more?
BTW, I wouldn't particularly want to edit in Lab, as I find it a bit counter-intuitive, but I suppose that may just be a matter of what I'm used to. I also used to find RGB editing a bit odd...
I think you're right. Lab is the halfway point with images. The source is lost but the destination is not committed. True, Lab is not profiled but you can still soft proof in the desired destination color space.
Since InDesign cannot convert to Lab on output, you would have to convert all in Photoshop. So maybe most people say, why bother with that, leave them RGB.
Pantone spots that need to go to CMYK are different though. Lab can be the source for those.
In order to display Lab it needs to get converted to RGB for display (you don't have a Lab monitor right?). So if you make edits based on your displayed soft proof, what RGB space are you working in? I'm pretty sure it's your monitor RGB (see my #8). So as long as you display the Lab image on your monitor and stay in a closed loop, there won't necessarily be a problem making a conversion from Lab to CMYK or displaying Lab.
It gets more problematic if you send out the Lab file. I would have a hard time replicating your softproof of Lab on my display, because you might be calibrated and profiled at 2.2 gamma and 5000K, and I might be at 1.8 and 6500K. Lab is going to display in our respective monitor RGB specs differently. If you convert the file to AdobeRGB and send it to me with a tag, then we at least have a chance of seeing the same softproof because now the file's RGB specs are the same—2.2/6500/Adobe Primaries (assuming our monitor's are accurately calibrated so the conversion into AdobeRGB is correct).
You could argue that there would be no harm in placing Lab and exporting a PDF/X-1a and letting the conversion to CMYK happen on the other end, but there's no advantage and there's still the problem of no source profile and a potentially inaccurate softproof at the other end.
Right you can see where it's going, but not where it came from.
I'm not seeing that, I just filled a Lab PS file with a color, dup'd it, put both into ID and exported to PDF/X-1a and got the same values. ID's Separation Preview is also showing the same separation.
OK. I see where you are coming from, Rob. I was assuming a single system or at least all monitor calibrations constant.
I don't quite understand what you mean by "other end" here:
I would assume that the workflow would be edit images in Lab in Photoshop, place in InDesign as Lab, export to a tagged CMYK PDF (like PDF/X-1a). That way nobody else needs to know/care about my Lab work. Perhaps that's what you meant above.
This all assumes that there is some reason to edit in Lab which as I mentioned, I do not happen to see... In any case, thanks for the clarification, Rob.
Sorry, I meant PDF/X-4 where the Lab objects would stay as Lab and need to be converted at output to the printers CMYK destination (the OP's late binding). Again, it wouldn't be a problem outside of softproofing.
That's right, but you cannot convert to Lab from source color using InDesign.
With an all Lab PDF there's no calibration, but unlike uncalibrated source color it can't be reassigned. Maybe that would be an advantage of sorts.
In other words, source profile is unknown, source appearance is committed, destination can be whatever you need it to be.
You can't commit the source appearance because the conversion for display is to monitor RGB—the appearance is dependent on the display spec's and will change accordingly.
That's why we have RGB editing spaces and profiles, so that you can commit to an appearance.
Let me explain
Say you have Pro Photo and you output.
The next user decalibrates your PDF and assigns Adobe RGB as source. Then converts to a given destination. The appearance relative to the first user, not preserved because of the decalibration.
Now the first user converts the Pro Photo to Lab.
There is no opportunity for the 2nd user to false profile because it's Lab.
Just a note, I don't think a Lab workflow would be useful, but you never know, maybe there's someone out there who wants ID to convert to Lab on output.
Lab has to get converted for display or print, so when user 2 opens the Lab file it will display in some RGB display space and I don't think it's ProPhoto. Whatever the RGB space is (it looks like monitor RGB to me) there's going to be an appearance shift unless the display RGB spec's happen to match user 1’s ProPhotoRGB (1.8gamma| 5000K | Custom Primaries).
You mention the 2nd user's soft proof but I was talking about file integrity, relative to the original artist (user 1).
If user 1 outputs no conversion (embedding source RGB profiles), and user 2 strips away the ICC (it happens quite a lot, unintentionally) the appearance relative to the first user is lost, and the appearance of subsequent conversions will not be what user 1 wanted (we are assuming user 1 has a properly calibrated monitor, just to eliminate that variable).
If user 1 converts to Lab, user 2 can't strip away an ICC., there isn't one.
But to address the 2nd user's soft proof, with no destination color established:
1. When viewing source RGB the display conversion is Source RGB > Lab > Monitor RGB
2. When viewing Lab, the conversion is Lab > Monitor RGB.
The difference with Lab is the first step is gone. It has been replaced with an already done file conversion. But the file conversion would honor both the gamma and white point of the source space, so I don't think you would encounter wild appearance shifts on two different calibrated profiled displays when viewing Lab color. Any difference would have to be attributed to the first step:
Source RGB > Lab
If user 2's display conversion (user 2 viewing RGB PDF) vs user 1's already done file conversion (user 2 viewing Lab PDF) is somehow different, the difference would be due to either BPC or Rendering Intents, or both.
The difference with Lab is the first step is gone. It has been replaced with an already done file conversion. But the file conversion would honor both the gamma and white point of the source space.
If that were true we would have no need of RGB profiles and everyone would be sending out Lab. The Lab space doesn't have a gamma or white point attribute, so when user 2 opens the Lab file, it gets converted into her monitor RGB space not ProPhoto RGB. It's her monitor RGB space that determines the gamma and white point of the display. There's nothing in the Lab file that tells user 2's color management system that the source view display was ProPhoto 1.8|5000K|Custom Primaries
There doesn't need to be. The ProPhoto1.8|5000K|Custom was already honored in the previous file conversion to Lab. Bottom line the Lab result
Pro Photo > Lab
is what it is, whether a display does it, or if it's a file conversion.
The reason people don't send out Lab is
1. From InDesign you can't convert to Lab, which means a bunch of extra conversions in Photoshop and duplicate files.
2. Lab is never a source, and it's not a device output (monitor, printer, press). With Lab you're in the intermediary. I'm on my way but I'm only halfway. So most people don't bother with it.
3. You can't read Lab values in Acrobat (at least I don't think so)
4. Lab does not yield as much design capability in Photoshop (filters, etc)
5. Illustrator doesn't have a Lab mode
6. InDesign has no Lab blending space
7. There are a lot of people who just don't like Lab color, because it's bigger than anything else (except ProPhoto), it's strange, and the numerical values are not user friendly.
Pro Photo > Lab
The problem isn't with the ProPhoto to Lab conversion, it's the Lab to monitor RGB conversion on the other end. The monitor RGB profile will be variable.
If you display Lab 50|0|0 on a monitor profiled at gamma 1.8 and then on a 2nd monitor profiled at 2.2, the same value is going to have to display darker on the 2nd monitor—it doesn't matter what kind of conversion got you to the 50|0|0 value.
I'm not sure about that, if you look at the 3D plot of Lab in Apple's ColorSync Utility, it plots as a cube with no gamut restriction, which makes sense because you can't display or print Lab:
http://www.zenodesign.com/scripts/lab.png
If you look at the plot of any display RGB profile like ProPhoto or AdobeRGB, they sit inside of the Lab cube because they have gamuts defined by their primaries. So both ProPhoto and AdobeRGB are smaller than Lab:
http://www.zenodesign.com/scripts/adobergb.png
http://www.zenodesign.com/scripts/prophotorgb.png
Message was edited by: rob day
If that's true, then source Pro Photo RGB:
100|100|100
that produces the Lab output
50|0|0
would also be inconsistent on the two monitors.
To summarize, this is what I think you’re implying:
1. When a user looks at a Pro Photo, or Adobe RGB, or whatever, Lab doesn’t figure in at all. Somehow the RGB file goes straight to the display RGB.
2. If RGB values do get converted to Lab in a file conversion, the initial color frame of reference is lost forever. When different users open up the Lab files on different calibrated profiled displays, they all see different results, even though the Lab numbers are fixed and the Lab color space defines the gamut of human vision.
3. If I take an RGB file, make a copy and swing that to Lab, the copy looks like the original on my display. But if I send both files to someone else, somehow there’s a chance the two could look different on that person's display.
4. If User 1 submits Lab files to User 2, soft proofing goes out the window.
5. Somehow user 2 could unintentionally wreck the source color, even ought there’s no profile to strip away. Bear in mind: user 2 is not trying to edit color. This person is building an InDesign document, or submitting to a RIP, or some other later stage part of the workflow. Both parties agree on the destination color space.
If you agree with all those things, OK, we can agree to disagree.
Technically with ProPhoto there are colors that can be lost in a conversion to Lab. But these colors belong to other species and aren't part of what we observe in the natural world, and I don't think they would cause disparity on different monitors.
It is my belief that the reason hardly anyone uses Lab is because it’s not a device space. Nothing is captured in Lab, there’s no Lab proofer, and there’s no Lab press. But it’s still the gateway for all conversions and the foundation for color management.
100|100|100
50|0|0
The 1.8 gamma is honored in a file conversion to Lab.
Again, the conversion to Lab isn't the issue, it's the display of the resulting Lab file. If it's displaying in monitor RGB then its display gamma could be anything. A profiled ProPhoto RGB file always displays as 1.8.
Of course, a display gamma can be anything. And the Lab image has no gamma.
But it's not a requirement with Lab. The 1.8 gamma of ProPhoto has been replaced with Lab values.
Here are 2 soft proof color conversions when viewing ProPhoto on 2 different calibrated monitors:
ProPhoto, 1.8 gamma, 5000K > Lab > Monitor, 1.8 gamma, 5000K
ProPhoto, 1.8 gamma, 5000K > Lab > Monitor, 2.2 gamma, 6500K
The image should display consistently on both. And Lab is the intermediary.
Now the first part of that chain is replaced with an actual file conversion. Yes, the resulting Lab file does not have a gamma or white point. But it doesn't need it. These attributes have been replaced with Lab values.
will still display consistently. It's not like the ProPhoto appearance was discarded in a conversion to Lab. The colors that make up the file are still there in Lab numbers, and can be soft proofed on a calibrated monitor.
So you're saying that the Lab value 50|0|0 will have the same appearance when the display profile is either 1.8 or 2.2?
No, I'm saying that the Lab will have the same appearance as the RGB from which it originated on the same monitor.
My monitor is calibrated to 2.2, 6500K. I can open a ProPhoto, convert to Lab. The appearance does not suddenly change, even though my monitor is not 1.8 gamma 5000K like ProPhoto.
I can send both the ProPhoto and the Lab to someone else with a monitor calibration of 1.8 gamma, 5000K. This person opens both the Lab and the ProPhoto and the appearance of both is consistent on his or her display.
The appearance from one monitor to the next may not be entirely consistent, because the mediums have different calibrations and color spaces. Much like printing on different substrates. You may convert a file properly for both substrates and the intent is to preserve appearance, but the appearance cannot be entirely consistent, because the color gamuts are different.
So yes, 50|0|0 Lab can look different on different displays. But so can 100|100|100 ProPhoto.
100|100|100 ProPhoto converts to 50|0|0 Lab, no matter what monitor is being used. Lab is always the intermediary, even if the conversion is a dynamic soft proof conversion that occurs automatically without user intervention.
The promise of color management was to ensure consistent Lab values in any conversion. To do this ICC profiles were required for the device dependent color spaces, to ensure a proper transition to and from the intermediary Lab.
If user 1 converts the file to Lab, we're already in the intermediary.
Sorry, I just can't agree with you on that one. If you send me a tagged ProPhoto file it displays to the profile's specs (1.8|5000) not my monitor specs (2.2|5500). It displays at 1.8 gamma on any display with an accurate monitor profile, the monitor doesn't need to be set to 1.8 for that to happen, that's the point of including the profile.
It doesn't display to the profile's specs. It translates to your monitor specs. Through Lab.
The monitor can't display ProPhoto. A conversion must take place.
When you convert a ProPhoto to Lab, do you see a big appearance shift?
If you sent both files versions to me, would they somehow look different on my monitor, side by side?
So if I open an untagged RGB file, set ProPhoto RGB as my working space, and customize its gamma to 1.0, the display changes accordingly—you're saying it's really displaying at my monitor's 2.2 and not the working space's 1.0?
Or, if the display of SWOP CMYK varies depending on the monitor characterization, then there could only be one monitor gamma setting which would display an optimal SWOP softproof—what would that be?
You've altered the ProPhoto color space. The new alteration is assigned to the image. The appearance changes because it's assigned, not converted.
Just like Grayscale color spaces. I can change a gamma or dot gain number and it is a characteristic of the resulting profile.
You can choose different gamma settings for monitors. The CMYK will be converted to Lab, then to the monitor space for a soft proof. Again, the gamma is a characteristic of the monitor ICC. A user should turn on Proof Setup and Simulate Paper white for proper CMYK display.
The original poster asked about editing in Lab, and it is completely valid although unusual. Most designers probably don't do it, but there are Dan Margulis disciples out there. If you choose to work in Lab you are not circumventing color management.
Predating color management, I used scanning software called Linocolor. Heidelberg's workaround for locking in source color was Lab output. So if you had a Tango scanner for example, it was an RGB device, and the capture was controlled with an RGB calibration file (Fuji transparency, Kodak reflective, etc, not ICC profiles). Once the scan was done you had a Lab image that could be edited further if necessary. The Lab being what it is, you didn't have to worry about it getting altered by accident. At the end of the process, you saved out a CMYK, using a Print Table to control separation parameters (total ink, black generation etc)
That's old school compared to high end digital cameras and ACR. But if someone wants to go Lab and treat it like a source space, OK, whatever floats your boat.
The only thing is, I don't believe Camera Raw has a Lab output, so that means an extra step in Photoshop.
Illustrator's lack of Lab concerns me. You can't even place a Lab image in Illustrator. Oh well.
Thinking more on the blend space in InDesign, that might not be a terrible issue after all. It is apt to cause confusion – if a Lab image interacts with transparency, InDesign will display it in the blend space, even though it is still Lab. To test, place a Lab, tick on Isolate blending and you can see the out of gamut colors shift. But this sort of thing happens anyway, if you place RGB and the blend space is CMYK.
If you output the Lab with transparency interaction PDF/X-4 from InDesign, you can see in Acrobat that the image does remain Lab. So hey, it seems to work.
I know that—but my question was—are you're saying it's really displaying at my monitor's 2.2 and not the working space's 1.0?
The image is 1.0, converts to Lab, then converts to the monitor which is 2.2. So yes, it is displayed at 2.2 in the final soft proof.
So then the display would not change appearance on monitor A running 1.8 and monitor B running 2.2 because the conversion into the 2 different monitor spaces would be accounted for by the monitor profiles, which have different gammas.
In theory no, but the two monitors have different color spaces.
Different white point temperatures can make significant differences in appearance. Just like paper with color casts. If I have a bluish stock, then a yellow stock, a relative colorimetric conversion to the CMYKs for each of these will try to account for the paper casts. But the appearance will always be different, because 0C 0M 0Y 0K don't look the same.
To keep things simple just consider gamma. If I convert RGB 100|100|100 from my custom 1.0 ProPhoto to 2.0 ProPhoto the resulting value is considerably lighter 150|150|150.
The conversion from my custom ProPhoto 1.0 to monitor B’s (2.2) profile would also produce a lighter display than the conversion to monitor A’s (1.8) profile, but monitor B's 2.2 target gamma is darker than monitor A's 1.8 target gamma effectively producing the same displayed gamma.
But with this very step you're going through the Lab portal again.
That's what makes the whole color managed environment work. Lab.
So if someone converts to Lab they can't possibly break CM. The only thing lost are the name and parameters of the RGB source (ICC profile) and the RGB numbers. But the appearance of color is completely and utterly intact, cemented in the file conversion to Lab.
That's why the old Linocolor workflow worked pre-color management. You didn't have to worry about someone altering untagged RGB appearance unintentionally, because the step to Lab occurred at the scanner capture stage.
Again – take any RGB file. Convert to Lab. Do you see a color shift? With the RGB and the Lab result side by side – do they look the same? I'm sure they do.
If you send both of those files to me, and I look at them both side by side on my display – will they look different? No.
So if I receive a Lab file, how can anything relative to source appearance be sacrificed? If it, and the source, side by side, would look the same anyway?
Right I understand that, I'm just pointing out that when you convert into two different monitor profiles there are also two different monitor characterizations happening—the physical gammas and white points which the profiles represent. So the conversion to monitor 2.2 is lighter in value than the conversion to 1.8 but it's displaying on a darker monitor—the display gammas on the two different monitors will match assuming the monitor profiles are accurate.
But given that, I think Lab will also display the same on the two different monitors—when I was worrying about the two different monitor profiles I had forgotten to consider the devices themselves. So I think in both cases monitor A and B match.
Thanks, Rob.
I'm not so sure about this ProPhoto to Lab thing now. If I fill a ProPhoto document with
0R 0G 255B
then convert to Lab, there is a significant shift on-screen.
If I fill ProPhoto with the same color, and convert to Adobe RGB, no shift on the display (and the numbers stay the same too). If I then take the Adobe RGB and convert to Lab, no shift. So going that route, strangely enough, I end up with what looks like a much better Lab match to the original ProPhoto (but may in fact not be).
I realize the original ProPhoto blue is way, way beyond my monitor. I guess it's beyond Lab too. But how is the display shift when converting from ProPhoto straight to Lab explained? My argument earlier was that a conversion to Lab has to happen as color translates from source to monitor, behind the scenes, when viewing any RGB image.
What's strange too is that I don't see the shift when converting from ProPhoto to Adobe RGB. I thought Lab was in between every conversion. But if I go ProPhoto > Adobe RGB, I get a different result than when I go ProPhoto > Lab > Adobe RGB. What sense does that make?
This may not matter a lot because the ProPhoto blue is something you would never see in a normal image. And so far with every RGB image I test, I see absolutely no shift moving to Lab. It only happens with the fringe ProPhoto blue.
Maybe you have thoughts on this.
(To the original poster I apologize if I am getting too far off subject)
I've never had much use for ProPhoto for press work because the gamut issues going to CMYK from Adobe RGB are bad enough. Conceptually I can see using it if you headed to some big gamut inkjet printer.
It also had not occurred to me that it's out-of-gamut to Lab, which is not obvious viewing the plots in colorsync utility 2. But given that it is, the shift on the conversion to Lab doesn't seem that surprising because I assume the rendering intent would be relative when moving a color through the spaces—values would need to be relatively spaced as they move from large to small spaces. It's not just 0|0|255 either—try making a blend from 0|0|255 to 0|255|255 and convert that.
I didn't want to complicate things with my last post, but if you work in one of the large RGB spaces, convert to Lab, and send that out obviously there's the chance that some of the original color intent could be lost.
OK. I still don't fully understand, but enough about ProPhoto.
Switching gears – let's assume that both artists and commercial printers subscribe to a late binding workflow.
This means that all files are set up in source RGB (or Lab), and conversion to the destination CMYK is done by the printer.
Images would normally be RGB. Swatches (except for [Black] could be Lab, or perhaps RGB.
Who benefits more from this, the designers, or the printer?
If the artist works with an accurate monitor profile and the printer either prints to a existing profile or profiles their actual printing conditions, then they both do. It's certainly better than the artist guessing what the press profile is by converting to a random or default CMYK profile, and/or blowing off monitor profiling.
What about "flying blind" with source color?
Meaning the artist has all proper color management in place, but has no way of knowing destination color, because the print buyer hasn't finalized who's printing, or the job specs.
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
