learning@70
Default Premiere Titler Font change
Dec 13, 2009 7:12 AM
How do I change the default font in Titler
    Dec 13, 2009 7:39 AM   in reply to learning@70
    Use a template.
    Dec 13, 2009 7:47 AM   in reply to learning@70
    Just start typing and hit one of the Title Stiles or make a New Style.
    Feb 24, 2013 10:20 PM   in reply to learning@70
    I just found this on another site and it works:
    you can create a template with the text set to what font/size/colour etc. that you need. To do this just create a title and change to your desired settings, then delete the text.
    Select the "templates" icon near the top left of the title designer window, select "templates" from the title menu or hit the shortcut "Ctrl+j".
    Select the little triangle/arrow icon at the top right of the templates window and select "Import current title as template" from the drop down menu.
    Select the same little triangle/arrow again and select "Set template as default still" from the drop down menu.
    Now when you create a new title it will open the title designer with the settings you chose.
    Mar 21, 2013 4:39 AM   in reply to johatk86
    I had asked this  before and got the usual "use a template or select a style" and in my head I'd never got around how this could be useful when having to change hundreds of text sheets set up on somone elses project passed to me to work on - and my ddefault was not the same as theirs.
    Having done this - its soooo easy --  thank you!
