I have tried to download flashplayer and it fails. I have followed the steps for trouble shooting on Adobe but no luck. I have PC Defender (F-Secure) as my antivirus and firewall. Any suggestions?
Hi, you didn't mention if you uninstalled the previous version first, but following is the link to do that.
http://kb2.adobe.com/cps/141/tn_14157.html Read over and follow the instructions carefully and be sure to Reboot TWICE after
the uninstaller is finished. This you will SAVE to your desktop.
Then this link that follows is to Install Adobe Flash Player. This is a direct downloand and install. You may want to read
the instructions first. There is on the opening page a Google Toolbar with a check mark and will be installed with the Flash
Player. Uncheck the box if you do not want it. Reboot Once after the install is completed.
http://get.adobe.com/flashplayer/
After the install is finished, go to this test site to have Adobe confirm the install & version #
http://kb2.adobe.com/cps/155/tn_15507.html
Then you can check any website and see if the sites are working as they should be.
Hope this works for you.
I tried what you said but got a message in DLM that said "failed to register". Still has not installed. I am running adobe reader 9.
Hi, what of Adobe do you have listed in Add/Remove? If DLM is there remove it. Whether you had a successful Uninstall
I don't know. If you did, then Flash Player 10 ActiveX will not be listed in Add/Remove.
When you tried to Install (if the above was successful) which version of FP?
Are you running as Administrator? From what I understand of IE8, this is necessary.
Any anti-virus running in realtime(running in the background) and sometimes a firewall will prevent an Uninstall/Install.
What firewall are you using?
Also go to Tools>Manage add ons and look for Shockwave Flash Object, it must be there and Enabled.
These are just a few things that may cause problems with an Uninstall and Install.
I have adobe version 9.2, DLM is not in Add/Remove.
no success loading any version of FP.
I am running in administrator, I believe.
I have disabled my antivirus and firewall but no luck loading. I use
F-Secure pc defender as my antivirus and firewall.
Shockwave Flash Object is not in my add ons. Where do I get it?
lilace3
Try downloading the offline ActiveX installer http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe (for Internet Explorer); save it to disk, then close all browser windows and run the downloaded installer.
This didn't work either.
Thanks for the input though.
Hi, most of the time when there is a problem in downloading FP, it is one or more add ons. To try to identify what it might
be, go into Tools>manage add ons and list for me all those "currently used" and "have been used".
If you are using any third party Toolbars, such as Google, Yahoo, AOL or any at all.
List all Java entries you have in manage add ons.
In addition, go to C:\Windows\System32\Macromed\Flash. Open the Flash folder and list the entries that are there.
Did you receive an error # with the "failed to register?"
Thanks, hopefully with this information we will be able to identify the problem.
I also have tried to install and uninstall several times. I do notice
this --- when I go to Add-ons the version that is listed is9.0
.124.0 Should this not have updated along with the new ver
sion of Flash? and if so why is it not?
Hi chipanna, No it should not be there; it is not "updated" per se it is replaced with the new version when the old version of Flash Player is Uninstalled and the new version of Flash Player is Installed.
You might want to supply the information that I requested of lilace3. Without knowing what the problem exactly is, a solution is just a guess. There are reasons I need certain information.
I could just tell you to go "here" and uninstall and then go "here" and install. But evidently everyone has already done that. So, either the uninstall did not work; the download did not work, or both worked and Flash Player is not working as it should. I could list all of the reasons for those 3 scenarios but it is not needed and it is time consuming. Instead I ask the pertinent questions to save you time and myself.
Thanks, post back with the information.
In manage add-ons
Java(tm) Plug-in 2 SSV He
Java Plug-in 1.6.0_17
Deployment toolkit
InC:.....Flash
KB923789
Also in add/remove I cannot remove Adobe DLM
Ok, thanks, that is part of the info. You only have 2 add ons?
And in your Flash folder you only have KB923789?, In your Flash folder?
And, if you see DLM in your Add/Remove, yes you can remove it. Hi light it and hit Remove.
Awaiting complete info.
yes to the first questions and I did highlighlight DLM an
d hit remove but it still would not remove. Now what?
Are you running as Administrator? On the Start button (left bottom), right click on it, does it say "run as administrator?"
On your add ons, if you can't list them all then the next best thing to do is follow this link:
Look for the one for "Windows", click on this and choose SAVE and put it on your desktop.
http://fpdownload.macromedia.com/get/flashplayer/current/install_flash_player_ax .exe
This is the Installer, click on this and choose SAVE and put it on your desktop.
To Uninstall:
Read and follow the instructions .
1. Go to Tools>manage add ons and DISABLE every thing that is listed there, say ok and close the window.
2. If you have any Toolbars, Google, AOL, Yahoo or any DISABLE them also.
3. Disconnect from the Internet
4. DISABLE OR PAUSE any Anti-virus/spyware that is realtime(running in the background)
5. DISABLE the Windows Firewall and if you use any other Firewall, DISABLE it also.
6. Close all browser windows, you want to be only looking at your desktop
7. Right click on the Uninstaller you put on your desktop and Click RUN
8. Wait until it is finished, then Reboot/restart your computer. Wait until it is completely rebooted. Then Reboot again
(to make sure the old Flash is removed)
Now to Install:
Right Click on the Installer that you put on your desktop and Click RUN
1. Wait until it is finished and then Reboot ONCE
2. Re-Enable all Firewalls
3. Re-Enable all Anti-virus/spyware
4. Re-connect back to the Internet
5. Open IE, go to Tools, manage add ons and look for Shockwave Flash Object and ENABLE it. Also ENABLE Java, but NOT the SSV add on. DO NOT AT THIS TIME ENABLE ANY OTHER ADD ONS
6. Go to http://www.adobe.com/software/flash/about Adobe will confirm if you have FP installed and what version
Then you can go to a website and see if FP is working as it should be.
I have done all you said and it appears to be working n
ow, but.......the Shockwave Flash Object is still 9.0.124.0
Any new suggestions?
One more thing. DLM still cannot be removed from the
add/remove list.
Hi chipanna, glad to hear that you are making progress. Did you go to the Adobe test site after you were finished and
what did it show?
The vs 9 of ActiveX should not be in add ons. I'll give you a link to follow for that. But first, go to Add/Remove and what of Adobe is listed there?
You may have your security settings too high and that would prevent the install of the ActiveX to the IE add ons.
Let me know about the Adobe test site and what is now listed in Add/Remove. If you have successfully installed, then don't be concerned about the DLM.
Adobe te
st site "Adobe Flash successfully installed
you have version 10,0,42,34 installed
Security setting is on Med/high. I tried it on just Medium with the same results
On add/remove
Adobe AIR
Adobe Download Manager
Adobe Flash Plaayer 10 ActiveX
Adobe Reader 9.2
Adobe Shockwave Player 11.5
What next?
Thank you.
Ok, that's good thanks.
Now do this: Close out all browsers, click on Start, click on My Computer or Computer, right click on Local Disk (C:) & click Open. Look for a folder WINDOWS, right click on it and click on Open, Look for a Large folder that says SYSTEM 32, right
click on it and click Open. Look for a folder that says Macromed, right click on it and click on open, right click on the folder that says Flash and click open. You should see one that says Flash10d.ocx and one that says FlashUtil10d.exe. These are your new Flash version 10.0.42.34 files.
Look to see if there is one that says Flash9b.ocx . If that is there, right click on it, a window will open up. Click Delete, say ok or yes to send it to the recycle bin. Then close the window.
Post back and let me know what you found.
Found three folders that weren't there before all this trouble
File.ocx 7.0.14.0
Macromedia Flash Player Updater 7.0 r 14
Get Flash.exe.manifest
All three dated 9/4/2003
Good job chipanna, go back and delete all 3 of those. They are old and they are preventing the install of the new ActiveX
that you need.
Important: Was there any of the other ones? Any Flash10d.ocx or FlashUtil10d.exe?
Don't forget to Reboot
Let me know.
Hi my name is kim and I was having the same problem with my flash p
layer. I followed the instructions in reply or page #14 as you told another person to do, and went to site i was having the trouble with and it worked finally, then i went to page #19 and followed those instructions and everything was fine i did not have the flash9b.ocx file so i closed that. now i need to know which if any add ons to turn back on... THANK YOU SOOOOOOOOOOOOOO MUCH, i have been installing and uninstalling this flash player for about two weeks and was just about ready to throw in the towel, again THANK YOU.
PROBLEM FIXED
Great you have get to work it.
HAPPY NEW YEAR!
2009/12/31 gobabygo41 <forums@adobe.com>
again THANK YOU.
Hi jannpann, Just checking to see if you solved your problems with FP also.
Thank you
