hi,
i install the part 1 without problem but for the part 2 i have this message on the attach file
Hello mbk28,
The issue you're experiencing is related to Mac OS X 10.6 (Snow Leopard) and has been documented in this forum here: http://forums.adobe.com/thread/486175?tstart=0
To use the BrowserLab extensions for Dreamweaver CS4 with Mac OS X 10.6 (Snow Leopard):
If you are installing BrowserLab extensions on Snow Leopard for the first time:
If you received an error message while trying to install the second BrowserLab extension with Snow Leopard:
Please let me know if you need further assistance.
Best regards,
Corey
Hi Corey,
BrowserLab was installed on my mac, but with a problem of acro bat, I had to reinstall all the suite.
I install CSI 1.0.2 and I have this message:
Best regards
Marc
http:/:www.marcolympics.org
Le 16 déc. 2009 à 15:52, Corey@Adobe a écrit :
Hello mbk28,
1. Install Dreamweaver CS4
2. Install the Extension Manager CS4 2.1 patch (available here: http://www.adobe.com/exchange/em_download/) and CSI 1.0.2 patch from http://www.adobe.com/support/downloads/detail.jsp?ftpID=4568
3. Follow prompts to install Browser Lab Extensions
1. Stop the “CS4ServiceManager” process (In your Activity Monitor, quit the process called CS4ServiceManager)
2. Rename ~/Library/Application Support/Adobe/CS4ServiceManager to ~/Library/Application Support/Adobe/CS4ServiceManager_bkp
3. Reinstall the second BrowserLab extension
Best regards,
Corey
Hello Marc,
Sorry, I'm a little confused by your response. There is no additional installer message in your follow-up. Did you intend to show me another message?
It sounds like CSI 1.0.2 is not installed on your machine. Please launch Extension Manager and go to Help (next to File) and choose About Extension Manager. This will bring up the about screen which displays the Extension Manager CS4 version installed. Please reply with the version number.
Best regards,
Corey
Hi Marc,
That could be the cause of the problem, but I'm not certain about that...
Please reply with the version number of Extension Manager CS4 you have installed and the version of the CS4ServiceManager.app file you have installed. The CS4ServiceManager.app file can be found in (Macintosh HD)/Library/Application Support/Adobe/CS4ServiceManager/CS4ServiceManager.app. Select the CS4ServiceManager.app file then go to File > Get Info to find the version number.
Best regards,
Corey
Hi Marc,
That's strange that Get Info isn't displaying the version number... However your version of Extension Manager indicates you have the 2.1 patch installed. When you installed CSI 1.0.2 did you receive any error, or did it successfully install?
Did you try performing the second series of steps? If not, please try this and let me know the results:
Best regards,
Corey
Hi Marc,
Just to be clear, when you tried step 2, did you rename the root or the user directory? You want to rename the user directory.
(2. Rename ~/Library/Application Support/Adobe/CS4ServiceManager to ~/Library/Application Support/Adobe/CS4ServiceManager_bkp)
Since your Get Info window is not displaying the CS4ServiceManager.app version, please send me your manifest.xml file (/Library/Application Support/Adobe/CS4ServiceManager/extensions/kuler/META-INF/manifest.xm l). You can send it to me directly at cogutch@adobe.com.
Best regards,
Corey
Hi Corey
Apologies for jumping in on someone else's thread but I have exactly the same problem:
I've had the earlier version of Browserlabs running for a while and was prompted, today, to grab the part 2 update.
Extension manager patched and all the other suggested solutions have been tried but I'm still getting the same message as MBK
Extension - 2.1.115
No Version number showing for Service Manager
Hi Marc, Pierre,
I'm sorry that you're both having this problem, and appreciate your patience. Please send me your CS4ServiceManager log files located here:
~/Library/Application Support/Adobe/CS4ServiceManager/logs/updates.txt
and
~/Library/Application Support/Adobe/CS4ServiceManager/logs/CS4ServiceManager.log
Please send them to cogutch@adobe.com.
Best regards,
Corey
Marc
You've sent this to the wrong address - your solution wouldn't fix
mine as I don't have CS5 installed
>Hi Corey,
>i thinl I fond the problem.
>just before installing the new beta of dream, I unisztall all the
>CS5 files (dream and catalyst) and I can install the file.
>So I think it's a problem with the cs5
Hi Marc
I found your Forum post yesterday and contacted Corey at Adobe
Same problem in so far as exactly the same error messages, etc
>Hi Pierre,
>if it's the wrong adress, where I have to sent the answer, I open
>this discussion?
>If you don't have CS5, we don't have the SAME problem, but a similar
>regads
>Marc
Hi Marc, Pierre,
Thanks again for your patience. Please try closing Dreamweaver and Extension Manager then navigate to:
(user)/Library/Application Support/Adobe/CS4ServiceManager/extensions/ConnectNow/1/META-INF/mani fest.xml
open the file in a text editor and delete the following attribute of the ExtensionManifest tag:
xsi:noNamespaceSchemaLocation="ExtensionManifest_v_1_4.xsd"
Save and close the file, then try installing the BrowserLab Extensions.
Please let me know if this resolves the problem.
Best regards,
Corey
Hello ae6dx,
Thanks for your patience. I'm sorry to hear you're having problems. Just to make sure, did you also run the CSI 1.0.2 update? If so, and it was successful, please check your (Macintosh HD)/Library/Application Support/Adobe/CS4ServiceManager/extensions/(all folders)/META-INF/manifest.xml files for the existence of "xsi:noNamespaceSchemaLocation". The updater should have replaced those 4 manifest.xml files. Please also reply with the version number of “ExtensionBundleVersion” of each manifest.xml file.
Best regards,
Corey
Thanks, Corey.
I was having the same issue as other folks here and it was just a matter of installing CSI 1.0.2 from http://www.adobe.com/support/downloads/detail.jsp?ftpID=4568
That apparently isn't installed via automatic updates.
North America
Asia Pacific
