hello again: i have an xml like this one, How can i change the values of the nodes <adposx> and <adposy> of the node array "YAYA" .I did that :
this.Pages.page.adverts[1].adposx= newvalue;
this.Pages.page.adverts[1].adposY= newvalue;
but it dont work
<Pages>
<page id="Page2">
<adverts>
<adfile>YOYO</adfile>
<adwidth>1</adwidth>
<adheight>50</adheight>
<adposx>514</adposx>
<adposy>200</adposy>
</adverts>
<adverts>
<adfile>YAYA</adfile>
</adverts>
<adverts>
<adfile>YUYU</adfile>
</adverts>
<adverts>
<adfile>YIYI</adfile>
</adverts>
</page>
</Pages>
as far as i know to do this requires good judgement on xml.
you have to first acquire as an xml object the node you wish to replace.
and then you can replace that node with another node or you can individually adjust 1 line but from a parent node.
var pg=<Pages>
<page id="Page2">
<adverts>
</adverts>
<adverts>
</adverts>
<adverts>
</adverts>
<adverts>
</adverts>
</page>
</Pages>
var pg:XML=<Pages>
<page id="Page2">
<adverts>
<adposy>200</adposy> </adverts> <adverts> <adfile>YAYA</adfile> <adwidth>1</adwidth> <adheight>50</adheight> <adposx>514</adposx> <adposy>200</adposy> </adverts> <adverts> <adfile>YUYU</adfile> <adwidth>1</adwidth> <adheight>50</adheight> <adposx>514</adposx> <adposy>200</adposy> </adverts> <adverts> <adfile>YIYI</adfile> <adwidth>1</adwidth> <adheight>50</adheight> <adposx>514</adposx> <adposy>200</adposy> </adverts></page></Pages>var xml=pg..page.child(0)//trace(xml)xml.replace([4],<adposy>newValue'</adposy>)
trace(pg)
basically you have to adjust a node at once or continue to replace
thanks it wotks... now i have another challenge. here is the xml script : i would like to be able to delete a node according to the attribut "id" of the node "adverts". ?????
<page id="Page1">
<adverts id="0">
<adfile>file1</adfile>
<adposx>212</adposx>
<adposy>375</adposy>
</adverts>
<adverts id="1">
<adfile>file2</adfile>
<adposx>7</adposx>
<adposy>69</adposy>
</adverts>
<adverts id="2">
<adfile>file3</adfile>
<adposx>83</adposx>
<adposy>303</adposy>
</adverts>
</page>
</Pages>
I tried like this but it didnt work :
function deleteme(evt:MouseEvent):void {
var who_Id:int=evt.target.parent.parent.id; // just to get the id number
var who:String=evt.target.parent.parent.name;
this.removeChild(evt.target.parent.parent);
this.evt.target.parent.parent= null;
delete Pages.page.adverts.(@id==who_Id); //can change who_Id by a number for test
trace(Pages);
