I'm trying to create a "motion" menu using just an audio file associated with the menu. The idea is to have a static menu with a background music.
I tried to to do this but when I build the DVD, Encore (CS4) complains about the pixel aspect ratio (says it is unsuported).
I guess that as it doesn't find any video to build the motion menu, its PAR isn't correct. Nonetheless I suppose that doing what I want to do is pretty standard.
Can someone please help me out?
I'm assuming that you're trying to add audio to a still menu.
Two questions: 1) Where do you get the menu (Adobe Encore library, created one in Photoshop, etc).
2) where did you obtain the audio and what is the format (MPEG, WAV, PCM, etc?)
Try the following first.
1) Create a new project. Use a standard still menu from the library
2) Add an audio track.
3) Preview the project.
If it works, you can trouble shoot it from there
Back in Photoshop, look under Image>Pixel Aspect Ratio. Make sure that it matches the PAR of your Project. I would say that it does not now.
One can easily have an Audio-only Menu, which is otherwise static.
Personally, I would use 48KHz 16-bit PCM/WAV Audio Assets, just to keep Encore from having to change this to 48KHz. Takes only a second in Audition, Soundbooth, Audacity, or other audio-editing programs, and keeps the load on Encore to zero.
North America
Asia Pacific
