HELP! Convert pdf file from legal size to letter size?
Jan 7, 2010 8:24 PM
Need you HELP!
I have Adobe Acrobat 7.0 Professuonal .
How I can convert pdf file from legal size to letter size?
All information should be same like on legal size, I just need make it smaller to letter size.
Thank you.
    Jan 7, 2010 8:55 PM   in reply to adobeik
    This is not necessarily the most effective way, but I simply printed to a new file with the option to shrink to fit paper (8.5X11). The document shrunk as a result. The PDF is attached.
    Jan 8, 2010 2:31 AM   in reply to adobeik
    Since there were no form fields in the file, I simply printed to a new PDF with letter as the paper size and selected
    to fit margins.
    Jan 8, 2010 6:00 AM   in reply to adobeik
    Reprinting/Refrying from Acrobat is no longer associated with best methods practice. If you have a DTP program you can import each page into the DTP program using letter size for each page. Scale the page, then create a new pdf file from there.
    Jan 8, 2010 11:30 AM   in reply to adobeik
    DTP is a "Desktop Publishing Application" Such as InDesign, Pagemaker...etc.
    Jan 8, 2010 7:37 PM   in reply to adobeik
    As far as printing to the Adobe PDF printer, DO NOT check the print to file. The printer should take care of that. If you print to file, you are printing to a PS file (NOT PDF) that would then have to be opened in Distiller to create the PDF. I had mentioned this may not be the simplest way, but it does the job for what you needed.
