Hi All,
I've built a Flex application which is calling coldfusion CFC through remote objects in order to retrieve data.
2 days ago, I've updated the server with coldfusion 9 and my issue is that I have sometime those kind of error messages :
[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Failed"]
[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Status 503"]
[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Status 500"]
[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Status 504"]
[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://servername/flex2gateway/'"]
It was also happening on Coldfusion 8 and even on one other sever with another application.
(but same logic Flex -> remote Objects -> CFC -> sql2005).
When we were still running CF8 I added this <add-no-cache-headers>false</add-no-cache-headers> to the service-config.xml file but with no success.
I do not know if it's related to this but I also sometimes have this error message :
[RPC Fault faultString="Channel disconnected" faultCode="Client.Error.DeliveryInDoubt" faultDetail="Channel disconnected before an acknowledgement was received"]
Most if time the application is running fine, but I want to avoid this errors.
For example yesterday I recieved +- 50 times the NetConnection.Call.Failed error and 20 times Channel disconnected error.
Do not hesitate to ask if I need to post CF9 settings summary or something else.
Thank you for your help.
Aubry
btw I am facing a worst issue ..
is there a patch for CF9 or BlazeDS to fix this :
[RPC Fault
faultString="Detected duplicate HTTP-based FlexSessions, generally due to
the remote host disabling session cookies. Session cookies must be enabled to
manage the client connection correctly."
faultCode="Server.Processing.DuplicateSessionDetected"
faultDetail="null"]
hi all, I managed to fix this. The best explanation is here. http://blog.crankybit.com/flex-remoting-over-ssl/
It turned out that I wasn't connecting on SSL because services-config wasn't configured for a secure channel. Once the services-config was updated ColdFusion needed to be restarted.
I do not know why this isn't better documented.
Deb
You must create a crossdomain.xml file. Solution is here: http://www.flexnedir.com/flex-ve-coldfusion-channel-connect-failed/
North America
Asia Pacific
