I've recently installed Eclipse Galileo and am trying to get a test Flex app using BlazeDS up and running with the Flex Builder plugin. I've got the exact same project and setup configured with Eclipse Ganymede and everything runs fine, but am completely stuck in getting it to work with Galileo.
I initially created the Flex Project with the J2EE server option using remote object access with LiveCycle. I also selected the create combined Java/Flex project using WTP. I'm using a Glassfish v2.1 server and use the default context root and content folder, and am also pointing it to the blazeds.war file. This is exactly the same way I set things up with Ganymede.
When I try to run the project, I get a status 404. If I go to the Flex Server properties for the project and ask it to validate the location, it says that it can't access the web server. I know the server is running and has the application deployed and the root folder and URL seem to be correct.
Is there anything that changed in this area between Ganymede and Galileo? Can anyone give me any other pointers regarding what to look for to track down the problem? I've looked at the .flexProperties files and they are exactly the same between the two, other than the workspace I'm using. I'm really stuck on this and would very much appreciate any help.
Thanks so much!
Renee
North America
Asia Pacific
