[svn:fx-trunk] 13456: Localization property file update 4.0.0.13453
Jan 12, 2010 11:20 AM
Revision: 13456
Revision: 13456
Author:   jimurphy@adobe.com
Date:     2010-01-12 11:20:00 -0800 (Tue, 12 Jan 2010)
Log Message:
Modified Paths:
    flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/SharedReso urces.properties
    flex/sdk/trunk/frameworks/projects/spark/bundles/da_DK/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/de_DE/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/es_ES/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/fi_FI/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/fr_FR/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/it_IT/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/ja_JP/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/ko_KR/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/nb_NO/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/nl_NL/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/pt_BR/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/ru_RU/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/sv_SE/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/zh_CN/components.pro perties
    flex/sdk/trunk/frameworks/projects/spark/bundles/zh_TW/components.pro perties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_da.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_de.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_es.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_fi.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_fr.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_it.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_ja.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_ko.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_nb.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_nl.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_pt.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_ru.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_sv.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_zh_CN.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/Config urationException_zh_TW.properties
    flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.prope rties
    flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.prope rties
