VinodChattergee
Reader extensions render failed. What would be problem?
Jan 18, 2010 10:07 PM
Dear All,
The form which I created using designer is working fine with acrobat, but when it opens in adobe reader all the scripts seems to be not working! Do we need to render the form with reader extensions before proceeding with adobe reader? With that assumption I tried to apply rights to the pdf from reader extensions (
http://localhost:8080/ReaderExtensions/
)  but it failed to render! What would be problem? – attached the screenshots for your review and feed back
Kind Regards,
Vinod Chattergee.S
    techies
    Jan 19, 2010 3:22 AM   in reply to VinodChattergee
    Vinod,
    Please use a valid RE credential. From the screenshot it appears that the Good Ubiquity credential was expired on Sep 1, 2009
    /Santosh/
    techies
    Jan 19, 2010 6:44 AM   in reply to VinodChattergee
    Before you go down that path what are the scripts expected to do? This will determine whether you
    need RE or not. Is Reader throwing some kind of error?
    Paul
    techies
    Jan 20, 2010 8:02 AM   in reply to VinodChattergee
    From what you have shown me here you can use Acrobat to Reader Extend the file. Do you have Acrobat? If not you can download a trial version and validate that it fixes your issue.
    Paul
    techies
    Jan 21, 2010 6:31 AM   in reply to VinodChattergee
    The client does not need Acrobat ....you do. Once you apply Reader Extensions to the form those features that it enables are on the form for all to use .... until the Reader Extensions are removed (either by opening the form in Designer or explicitly removing them). You would send them the Reader Extended version of the form for distribution.
    Paul
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
