How can we release memory when removing tiles from a view?
Do we have to handle this inside the tile?
Or is it supposed to be done by the shell itself ?
Thank you!
Thanks for the answer. However, I've made a little test application (with property allowContentDelete="true"), and where I can add tiles (very simple Flex tiles, with one label and two text input).
Adding and deleting tiles multiple times made the memory goes up, and was never released (Both Firefox and IE).
It is really important for us to get the memory released, as we have many large modules that can be loaded several times.
Any advice?
Thank you!
Update: With the same application, AIR seems to do a better job, but AIR is not an option for us.
I spoke with the Developers about this issue. Unfortunately there doesn't seem to be an immediate solution:
Mosaic runs into the same flashplayer memory issues that other apps using SWFLoader experience. Mosaic 9.0.1 will include some memory optimization to help reduce the problem... [Engineering is] working ... to isolate the issues and get a fix.
North America
Asia Pacific
