This discussion is archived
vicente62
ACR window in 10" netbook
Jan 21, 2010 7:54 AM
I bought a netbook to 10 "and I was able to install Photoshop CS4  but the ACR window is too large and the bottom is beyond the verge of developing screen.
Is it possible to resize the ACR or there another solution?
thanks
    Jan 21, 2010 8:19 AM   in reply to vicente62
    I join to this question, for I am thinking about buying a netbook. However, I would like to know the minimum size of the monitor in pixel dimensions, not the physical size. Is this the same with different versions of ACR (version 4 vs version 5)?
    Gabor
    Jan 21, 2010 11:22 AM   in reply to Panoholic
    The minimum display dimension supported in Camera Raw is 1024px x 768px...that is the smallest possible UI designed arrangement. There's nothing the ACR team can do to alter that since the minimum dimensions of Camera Raw are dictated by the minimums display size of Photoshop which is also 1024 x 768.
    Jan 21, 2010 11:46 AM   in reply to vicente62
    ACR requires a resolution of 1024 × 768.
    Less than that and it will open but can't be used. I tried it on my netbook which is 1024 × 600.
    No luck
    Jan 21, 2010 12:03 PM   in reply to John Joslin
    Jan 26, 2010 9:15 PM   in reply to John Joslin
    For what it's worth PS CS4 / ACR 5.6 working great on a HP Mini 5101 with optional 1366x768 & 2gb memory.
    Jan 29, 2010 6:21 AM   in reply to vicente62
    You can expand the harware limitation via software by desktop extension via normally system utility. I use it on my 9" netbook.
    Jan 29, 2010 7:16 AM   in reply to Marco N.
    OK.
    And what is this software?
    My netbook only allows 1024 × 600 px resolution.
    Jan 29, 2010 8:20 AM   in reply to vicente62
    I use this EEE PC utility, other netbook should have similar utility:  http://www.youtube.com/watch?v=9NCBkouIXag
    Mar 24, 2012 3:06 AM   in reply to vicente62
    I have the same problem. I also have a netbook with a 1024x600 px display. ACR will work and all the adjustments are operational.  The problem comes when you want to 'open image'.  Simply hit 'return'  This is the default operator in ACR and it will now open in PS.
    I cannot find how you can change the output resolution.  If any one has any ideas, let me know.
