robertgravesly
Exporting with embedded frame counter?
Jan 21, 2010 1:56 PM
I have a client who wants to review my edit, but she needs a reference counter visible on the footage so she can make constructive notes, and reference specific moments in the rough cut.
How do I export/encode an flv file which has a visible frame counter embedded in the corner of the frame?  Can I also make the time code of the original video files visible too, also for reference?
Thanks Kindly,
Robert
    Jan 21, 2010 2:01 PM   in reply to robertgravesly
    Use the timecode effect on a transparent track before exporting.
    Jan 21, 2010 2:20 PM   in reply to robertgravesly
    I believe that this will be more difficult. One could do two Timecodes, per Harm's suggestion. However for this second, one would have to reset the 00;00;00;00 so that it matches that of the In Point of each Clip. I am not sure that the Timecode Effect in PrPro can do the reset (and certainly not automatically), but wonder whether the Timecode Effect in AfterEffects can. I have not tried it. It would still be quite a bit of work, but not impossible. Maybe some AE guru can comment, or maybe there is something in the Timecode Effect in PrPro, that I am just unaware of. Gotta' go poke around it, as I have only used it per your first request.
    Jan 21, 2010 2:27 PM   in reply to Bill Hunt
    Just by looking at the Timecode Effect, you can also apply it to each Clip and it WILL automatically display for that Clip.
    Just combine that with Harm's way with the Transparent Clip, and position them in different parts of the screen.
    PS - I have only used Harm's way, or for an Exported file with all Clips combined. Learned something new here.
    Jan 21, 2010 2:34 PM   in reply to Bill Hunt
    One last comment. If you apply the Timecode Effect to a Clip, where there is Motion>Position, the Timecode display will animate with it.
    Jan 21, 2010 2:35 PM   in reply to Bill Hunt
    For the media timecode, you need to add the Timecode effect to the clip, as Hunt said.  But you need to set the effect to Media (the default is Clip), otherwise it will show you the TC relative to the in/out points of the clip in the sequence.
    -Jeff
    Jan 21, 2010 2:39 PM   in reply to Jeff Bellune
    Unfortunately that is one of the drawbacks of using HDVSplit for HDV material: Media will always start with 00:00:00:00 as does clip.
    Jan 23, 2010 7:36 AM   in reply to robertgravesly
    Robert,
    I haven't figure out yet how to make the camera's own footage time code visible, which would be an absolute identifier regarding the origination of clips within the long original .avi file.
    Some cameras will "burn" in the counter. Be careful, if yours will allow for this, as you are not likely to want a TimeCode burned into the footage. We probably get more requests for ways to "remove" such, once done. Now, if one could utilize metadata, and turn-on/turn-off display in the footage, as would be required...
    Jan 23, 2010 7:48 AM   in reply to robertgravesly
    What is the format and codec of your source files?  Did you read my post #5?
    -Jeff
