johnzli
Confirmation upon browser window close event
Jan 25, 2010 11:53 AM
Our web application open a popup browser window contains a cutomized LiveCycle workspace from where the user submit a data form. I want to implement a feature that when the user close the browser window, a message box will pop up for user's confirmaiton (OK to close the window, Cancel to remain in the workspace window). Here is my code:
In javascript:
    <script LANGUAGE="JavaScript">
        window.onbeforeunload = confirmExit;
        var needToConfirm = true;
        var confirmMsg = "Are you sure you want to exit this page?"
        function confirmExit() {
            if (needToConfirm) {
                alert("Event triggered!");
                event.returnValue = confirmMsg;
                //return confirmMsg;
        function setNeedConfirm() {
        function releaseNeedConfirm() {
            needToConfirm = false;
     </script>
In *.mxml:
     flash.external.ExternalInterface.call("releaseNeedConfirm"); or flash.external.ExternalInterface.call("setNeedConfirm");
This approach works perfectly with IE, but for some reason it does not work with FireFox. I confirmed that the line alert("Event triggered!") is reached in FF, but no confirmation box is popped up.
Anyone can help me here?
John
    Jan 25, 2010 9:17 PM   in reply to johnzli
    Just change the line of code:
    as the following;
    event.preventDefault = confirmMsg;
    Hope this will work!
    Nith
    Jan 26, 2010 6:27 AM   in reply to johnzli
    The code I mentioned is applicable only to FireFox.
    To make your logic work on both browsers, you need to find out the browser type and should handle the event accordingly.
    -Nith
    Jan 26, 2010 6:30 AM   in reply to johnzli
    You can detect the browser type by:
    var browser=navigator.appName;
    var b_version=navigator.appVersion;
    var version=parseFloat(b_version);
    alert("Browser name: "+ browser);
    alert("Version: "+ version);
    -Nith
    Jan 26, 2010 6:37 AM   in reply to johnzli
    I will try to make an example and then let you know.
    Nith
