Illustrator can't find new font
Feb 11, 2010 9:50 PM
I am trying to use a new font I just downloaded online. When I try to use the font it doesn't show up in the selection. I looked and the font is located in my user > me > library > fonts folder but still won't find it. I even tried to put it in Macintosh HD > Library > Fonts with also no luck. I tried this with multiple fonts to see if I have the same issue...sure enough, I did.
These are .ttf files.
It's funny because all the Adobe programs refuse it but programs like TextEdit, and Font Book seem to find it fine.
Any help?
System: Mac OS X Version 10.6.2
    Feb 11, 2010 10:11 PM   in reply to BreathOTroof
    Since you do not have any other font management program remove the font fro where you placed them.
    The open Font Book. Select All Fonts.
    The drag the folder or individual fonts into the middle window of Font Book where the fonts are listed and let go.
    The fonts will be added and Ilustrator will be able to read them.
    Feb 12, 2010 12:19 AM   in reply to BreathOTroof
    Breath,
    This seems to imply that your new font is not really viable, corrupt even: Illy is maybe more sensitive than anyone else, because Live Type is both text and changeable shape, so the font has to meet certain requirements above and beyond being an assembly of letters.
    In this case, the font seems to be bad enough to annoy her sisters as well.
    I believe what they are trying to tell you, in their gentle way, is: That is not a font, (This is a font, being added when you pick a good one).
    Feb 12, 2010 1:18 AM   in reply to BreathOTroof
    Breath,
    Obviously, that points in another direction. You may try to Move the folder , which is a reversible resetting of your preferences. If that does not help, maybe one of the  Other options (link from the same page) may be relevant.
    Feb 14, 2010 2:45 AM   in reply to BreathOTroof
    Breath,
    The name of the preference file itself should be Adobe Illustrator Prefs on a Mac. But that is all I know, apart from the partly eaten apple shape.
    Feb 16, 2010 10:39 PM   in reply to BreathOTroof
    In CS3 it's [User]>Library>Preferences>Adobe Illustrator CS3 Settings>Adobe Illustrator Prefs
    Peter
    Feb 20, 2010 6:41 AM   in reply to BreathOTroof
    Breath,
    I moved the entire folder Adobe Illustrator CS4 Settings to my desktop, I noticed after I opened Illustrator after that it made a new folder with default preferences...but still no change, still cannot find a font as common as Myriad Pro.
    Then it is something else.
    PS: Problem is also in all other programs such as InDesign, Photoshop etc
    Uninstalled and reinstalled CS4 but problem still continues.
    Did you use the Clean Script in between? http://www.adobe.com/support/contact/cs4clean.html
    Jan 15, 2011 4:56 AM   in reply to BreathOTroof
    signup only takes a minute ... oh yeah?
    Then fix your god damn validation. That's one.
    Another one is ... Why don't you keep your mouthes shut if you can't answer a simple question but only suggest the most stupid suggestions ... like editing the "Adobe Illustrator Prefs" file just to install a stupid font?
    Do we now need to fix your stupid, stuffed-up coding now, too, apart from paying mega bucks for your bugs filled, incompetent software? Has it come that far now? Well then good luck to all your loser Professionals at Adobe. Keep hugging and telling each others how good you all are. You are the only ones that believe this crap.
    So now you an block me for being so rude to tell the truth! Fed up with your bull....
    Jan 15, 2011 5:28 AM   in reply to BreathOTroof
    Jacob should probably not be giving advice to someone on the Mac system because no matter how many times this is posted he always tells it his way.
    But when trashing the preferences on a Mac what you really need to do is trash the entire Settings folder, as is probably true of the Windows platform…because the folder itself can become corrupt. Also as has recently been posted so can the permissions for that folder and its content.
    This is how you find the Adobe Illustrator settings folder
    1. Quit Illustrator.
    2.Go to User/username/Library/Preferences/ Adobe illustrator CS4 Settings and trash the settings folder, the whole folder not just the contents of the folder..
    3. Start Illustrator. Illustrator creates a new preferences file.
    4. Also you may on occasion have to trash the com.adobe.illustrator.plist file also in the same User/username/Library/Preferences/ directory but a little further down.
    Then check the permissions you do that by using the disk utility and then manually checking it by right or control clicking on the Illustrator icon and going to get info to the bottom you will see where you can change the sharing and permissions you may have to change the permissions for all the users listed though on my Mac it works fine this way.
    However if it is a question of the fonts not showing up it may not be the settings for Illustrator depending on what font manager you are using it maybe the font manager or something wrong with the fonts or the system itself.
    i have had this happen to me as well after updating software but for sure I do not recall what software it was that causes this.
    But I use Font Agent Pro and by quitting and restarting Font Agent Pro seemed to always fix it.
    I suggest getting a font manger other than Font Book though some users are happy with Font Book.
    If you add your fonts with font book they will show up in your applications.
    Trying to load them yourself is probably not so helpful as you might think best to use something like FAP or Linotypes free type manager I think it is called font Explorer.
    Jan 15, 2011 7:08 AM   in reply to Wade_Zimmerman
    When a font is invisible in an Adobe application (not that uncommon) there usually is something wrong with the font cache. To delete the font cache, use Onyx (can be found here http://www.macupdate.com/app/mac/11582/onyx ). It has choices under Fonts for deleting font caches for system and users, Adobe, Microsoft and Quark. When done, restart machine and try again.
