acrobat 9.3 windows 7 64 bit
Feb 18, 2010 7:20 PM
...seems very flaky
Anyone else having issues?
Issues include: failure to export (with no rhyme or reason - I can crash indesign with an export that will work fine the next time I start).
Acrobat crashes on exit.
My only suspects (and they're all long shots):
dodgy ICC profile?
incompatibility with a explorer extension or other ap (using font agent pro4 - but get crashes when its not running)
    Feb 23, 2010 7:43 PM   in reply to getho
    I don't have an answer, but 11 minutes is not a very reasonable time frame to wait for an answer, You would likely get an answer within 24 hours, maybe you get lucky and get one within the hours. Please by patient.
    Feb 24, 2010 7:14 AM   in reply to getho
    There is a problem with the forum that is preventing answers to your question...I finally got it to come up with the reply box by repeatedly tring to post blank replies.
    Had Acrobat Pro 9.3 crash ID once, but I don't remember why. Usually this happens when you try to do too much too fast. I tell everyone using Windows  to slow down, take your time or you will crash/hang the operating system. This is mainly a problem with fast typists who drink a lot of coffee.
    My biggest problem is 9.3 "not responding" until a few minutes after you open a pdf.
    Feb 24, 2010 11:34 AM   in reply to getho
    There are a few PC's at my office that are kind of in the same boat as you.
    Acrobat 9.3.1 Pro is very slow when opening PDF's from network locations and when you close Acrobat it just hangs....and eventually closes.
    Running 2.67Ghz Xeon processors, 8GB of RAM, running Windows 7 64-bit, so PC horsepower should not be an issue.
    Feb 24, 2010 3:51 PM   in reply to getho
    Opps, sorry. I missed the date. There seem to be several posts coming out on Win 7, 64-bit. Maybe someone will come out with a solution for you soon.
    Looking at some of the posts, I remember seeing something similar related to the "processing" with AA8 and VISTA. I did not get a crash, but it delayed opening. As I remember it is a matter of turning off part of the reading function for the PDFs. If you can find that in AA9 preferences, it might be worth a try to turn off.
    May 7, 2010 4:40 PM   in reply to getho
    same problem here - just upgraded in the last month to Windows 7, running Acrobat 9.3 STD.
    HP elitebook 8730W, 1/2 gig on the nvidia Quadro graphics card and 4 gb ram - so that's not the problem, 2.8 ghz on the intel core duo - better not be the problem.
    very unstable - crashes every time I try to open more than 1 pdf at a pop.  Also routinely crashes when doing simple thinks like putting a sticky note on a doc.  Very slow on any search functions.
    I've lost many many hours to this program in the last month.  any permanent solutions would be greatly appreciated.
    May 7, 2010 4:56 PM   in reply to getho
    nice fix Getho - opened about 50mb worth of pdfs with no glitch.  also everything is moving along much faster - searches taking seconds instead of 5 minutes.
    not sure if that makes it so I can't read my document out loud (good thing I'm not blind!), but I'll go with the trade off.
    Thanks again.
    May 26, 2010 6:45 AM   in reply to getho
    I'm having the same problem too.  Even with single PDFs the accessibility feature is a huge time waster, but the crashes when opening mutliple PDFs at once is a huge bug. Has anyone actually reported this as a bug to adobe?  The accessibility feature is nice, but it should be something you can toggle on and off (and should be off by default). I would assume that most users of Acrobat Pro are not visually challenged.  Acrobat Reader might be a different matter, but this option really gets in the way of productivity.  It takes too long to prepare the document, and if you just need to quickly view a lot of PDFs it's detrimental to a productive workflow.
