Screen Recording
Feb 22, 2010 10:22 AM
Can anyone suggest screen recording software that can output a file in to Premeier CS3 and give me a top quality file for editing?
I've tried Camtasia but the results are rubbish (fuzzy picture quality).
I don't particularly want to learn a new package, I just want to record the screen, import the video in to Premiere and then edit the whole thing from there.
What about the Adobe product Captivate?
Chummy
    Feb 22, 2010 10:41 AM   in reply to Top Branded Clothing
    The topmost 3 tutorials on this page:
    BDVS Tutorials
    were done in CS4 using Camtasia source footage and FLV encoding in Squeeze.
    Are they fuzzy to your eye?  I thought they turned out pretty good.
    -Jeff
    Feb 22, 2010 3:30 PM   in reply to Top Branded Clothing
    Top Branded Clothing wrote:
    record in Camtasia, output AVI, edit that in CS4 and render to whatever. No probs, right?
    No problems, but attention to detail.  When you finish your screen capture in Camtasia, *do not* resize the captured video.  Produce at the recording dimensions.  I use AVI files with the TechSmith codec even in Pr.  The Pr sequence must exactly  match the frame size of your Camtasia footage. If you use screen grabs or other still images in your sequence, they will be placed in the center of the frame.  If the image(s) are smaller than the sequence frame size then check the Anchor Point location.  If it's on a half-pixel dimension, shift it up/down/left/right a half-pixel so that it's on a whole pixel position.
    PS Why do you use Squeeze for FLV and not A.M.E.?
    The AME produces good results, but I have more control over the bit rate (and therefore the final file size) and other encoding parameters in Squeeze.
    -Jeff
    Feb 22, 2010 11:32 PM   in reply to Top Branded Clothing
    You might want to try FRAPS at fraps.com. The native codec can be edit in Premiere Pro and it is only $37.00. You must use Windows Aero in order for it to capture the Windows desktop.
    Aug 9, 2010 9:21 AM   in reply to Top Branded Clothing
    I use 'My Screen Recorder' from http://www.deskshare.com/screen-recorder.aspx
    There is no learning curve, I select the format I want and click 'start recording'.  The recording gives a clear picture in both the AVI and WMV recording format - I use the high motion/frame rate profile.  Both the AVI and WMV recordings it creates import easily into Premiere.
    Aug 9, 2010 9:24 AM   in reply to Quality-Video
    Not familiar with that product, but like other Deskshare programs. With the AVI, what are the specs. of those files from the program?
    Personally, I'd shy away from WMV's, due to their structure and compression, but that is just me.
    Thanks for the info,
    Aug 9, 2010 3:19 PM   in reply to Top Branded Clothing
    And now for the poor man's approach.
    If your laptop has a S-video or composite video output, you can route the laptop to a camcorder and then capture via firewire (assuming the camcorder supports AV-D conversion)
    Set everything up in clone mode--camcorder on in VCR mode but stopped-capture into PrPro by F5.  If your camcorder swalks about no tape, put a blank tape in.
    You can only do this in DV.  The HDMI port typically has copy protect features that if it doesn't detect a HDCP enabled device will block the capture.
    Aug 9, 2010 4:59 PM   in reply to SFL46
    You know, I never thought of doing it that way. I'm sure that someone must have mentioned that in the past, but it did not sink in, until your post. Now, I have to set things up and give it a test.
    Thanks for the mention. I suggest the camera, with pass-through, for A-D work, if an A-D bridge is not available, but never thought of doing it the other way.
    Aug 10, 2010 2:02 AM   in reply to Bill Hunt
    In my experience, going via interlaced DV really does degrade detail - especially text.  Much better to stay in a lossless workflow until final compression.
