Can someone help in figuring out this error!
Feb 23, 2010 12:04 PM
This is my query:
<cfquery name="q" datasource="#APPLICATION.DB#" USERNAME="#APPLICATION.UN#" PASSWORD="#APPLICATION.PW#">
        select    groupidfk AS group
        from    #variables.tableprefix#permissions
        where    rightidfk = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.right#" maxlength="35">
        and        resourceidfk = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.resource#" maxlength="35">
</cfquery>
This is the error I get: Incorrect syntax near the keyword group
If I take the alias out and not rename it group then the query works just fine.  But I need that in there for a bunch of other code to work properly.
Ideas?
Anthony
    Feb 23, 2010 12:11 PM   in reply to AJBJ
    You might want to check the reserved words for your DB implementation.  However I couldn't think of any SQL DB which would not have GROUP as a reserved word (eg: because of the GROUP BY statement).
    If you need that column to be called "group", then investigate how your DB escapes keywords. It could be something like square brackets, or back-ticks or something like that.
    Adam
    Feb 23, 2010 12:14 PM   in reply to AJBJ
    In at least some DB's you can get around the reserved word by putting quotes around it
    select xyzcolumn as 'group'
