I need to figure it out, how to have semi-transparent track for VScrollBar. content behind Scrollbar should be visible. When I have skinned Scorrlbar and set alpha to track, it doesnt work, when I have set alpha to s:Scroller, whole content was semiTransparent, so I dont how to do that. Is it possible?
thanks
<!--- Defines the skin class for the HScrollBarSkin's track. The default skin class is HScrollBarTrackSkin. -->
<components:DefaultButton id="track" left="0" right="0" height="100%" width="30"
focusEnabled="false" alpha="0.5"
skinClass="my.scrollbars.VScrollBarTrackSkin"
<!--- Defines the skin class for the HScrollBarSkin's thumb. The default skin class is HScrollBarThumbSkin. -->
<components:DefaultButton id="thumb" width="28" horizontalCenter="0"
focusEnabled="false" visible.inactive="false"
skinClass="my.scrollbars.VScrollBarThumbSkin"
I've also try to set alpha inside my.scrollbars.VScrollBarTrackSkin, but still doesnt work. I;m using SDK Beta 2
Beta 2? *gasp*
You should update to a new nightly build, ASAP. http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
I managed to get a semi-transparent VScrollBar track in Flex 4 Scroller by creating a custom VScrollBar skin and setting the skinClass style using CSS.
Main app:
xmlns:mx="library://ns.adobe.com/flex/mx"
backgroundColor="red">
<s:controlBarContent>
<s:Label id="sdkVer" initialize="sdkVer.text = mx_internal::VERSION + ' | ' + Capabilities.version;" />
</s:controlBarContent>
<fx:Style>
@namespace s "library://ns.adobe.com/flex/spark";
@namespace mx "library://ns.adobe.com/flex/mx";
s|Scroller s|VScrollBar {
skinClass: ClassReference("skins.TransVSB");
</fx:Style>
<s:Scroller width="500" height="400">
<s:Group>
<s:TextArea text="The quick brown fox jumps over the lazy dog." height="900" width="90%" />
</s:Group>
</s:Scroller>
</s:Application>
And my custom VScrollBar skin, skins/TransVSB.mxml, is as follows:
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
minWidth="15" minHeight="35"
alpha.disabled="0.5"
alpha.inactive="0.5" >
<fx:Metadata>
[HostComponent("spark.components.VScrollBar")]
</fx:Metadata>
<fx:Script fb:purpose="styling">
/* Define the skin elements that should not be colorized.
For scroll bar, the skin itself is colorized but the individual parts are not. */
static private const exclusions:Array = ["track", "thumb", "decrementButton", "incrementButton"];
override public function get colorizeExclusions():Array {
return exclusions;
override protected function initializationComplete():void {
useChromeColor = true;
super.initializationComplete();
</fx:Script>
<s:states>
<s:State name="normal" />
<s:State name="disabled" />
<s:State name="inactive" />
</s:states>
<!--- The default skin class is VScrollBarTrackSkin. -->
<s:Button id="track" top="16" bottom="15" height="54"
alpha="0.2"
skinClass="spark.skins.spark.VScrollBarTrackSkin" />
<!--- The default skin class is VScrollBarThumbSkin. -->
<s:Button id="thumb"
skinClass="spark.skins.spark.VScrollBarThumbSkin" />
<!--- The default skin class is ScrollBarUpButtonSkin. -->
<s:Button id="decrementButton" top="0" enabled.inactive="false"
skinClass="spark.skins.spark.ScrollBarUpButtonSkin" />
<!--- The default skin class is ScrollBarDownButtonSkin. -->
<s:Button id="incrementButton" bottom="0" enabled.inactive="false"
skinClass="spark.skins.spark.ScrollBarDownButtonSkin" />
</s:SparkSkin>
Peter
Or you could try setting it via ActionScript and no custom skin needed.
<s:HSlider id="sl"
minimum="0.0" maximum="1.0"
value="1.0"
snapInterval="0.1" stepSize="0.1"
change="sl_changeHandler(event)" />
<fx:Script>
<![CDATA[
protected function sl_changeHandler(evt:Event):void {
scrllr.verticalScrollBar.track.alpha = sl.value;
</fx:Script>
<s:Scroller id="scrllr" width="500" height="400">
<s:Group>
<s:Rect width="100%" height="900">
<s:fill>
<s:LinearGradient rotation="45">
<s:GradientEntry color="red" />
<s:GradientEntry color="haloGreen" />
<s:GradientEntry color="haloBlue" />
</s:LinearGradient>
</s:fill>
</s:Rect>
</s:Group>
</s:Scroller>
</s:Application>
Peter
@ Peter
Very nice elegant solution indeed.
Thank you, Peter.
However there is one strange inconsistency:
if I add to the function two other elements -
scrllr.verticalScrollBar.thumb.alpha = sl.value;
scrllr.verticalScrollBar.incrementButton.alpha = sl.value;
the thumb and the bottom incrementButton are changing their transparency, but the top incrementButton completely ignores the change - it stays completely opaque.
Any particular reasons for that?
FTQuest
@FTQuest,
Sure, the top one is the decrementButton skin part. The incrementButton is the bottom button.
scrllr.verticalScrollBar.decrementButton.alpha = sl.value;
Peter
Peter, (or anyone else
) is it possible to move vertical scrollbar above content? I mean I want to see scrolled content behind sme-transparent VScrollBar. something like minViewportInset=-30 just for right side. (i'm not talking about scroll position, but move scrollbar component inside Scroller
thank you
@franto,
I dont know of a way off the top of my head, but I'm not a Scroller expert.
I tried setting the "right" property on the verticalScrollBar but that didnt seem to work. The only other idea I had was to disable horizontal and vertical scrollbars on the Scroller altogether and use your own s:VScrollBar in the main app and just position it over the Scroller wherever you want (you could just wrap the Scroller and VScrollBar in a s:Group container or something).
Peter
Regarding moving the position of scrollbars in a Scroller:
You can't reposition the scrollbars that are inside of a Scroller. Scroller uses its own layout algorithm to position the scrollbars (in order to support auto scroll policies).
Scroller is designed not to be re-skinned beyond changing the skin of its VScrollBar and HScrollBar. Just like franto kormanak did above, if you would like to move scrollbars around you are encouraged to hook up your own VScrollBar/HScrollBar instead of using a Scroller. See http://flexponential.com/2009/10/09/changing-the-position-of-the-scrol l-bars-in-a-spark-list/ for an example.
North America
Asia Pacific
