I am not able to convert word file to PDF using Adobe Acrobat 9 Standard. When I try to convert, it starts the process and in between I am getting this prompt, as shown in figure below and the conversion process stops. The PDF is not created.
Note: The filename 'Acr85.doc' in the above prompt keeps changing and is random.
I tried clicking Yes, No and Cancel on the above prompt, but the conversion process just stops and PDF is not getting generated.
I am able to create PDFs from web pages. No issues with that. Not working only with Word.
Can someone help me with this.
Vinay Jaassiel Kankipati
Technical Writer
I already tried saving the word file in the first attempt, but getting the same prompt. I am able to print the word file as PDF, but I am not getting the bookmarks in PDF automatically. I selected bookmarks by:
1. Opening the word doc.
2. Adobe PDF menu> Change conversion settings option> Bookmarks tab
3. Selected the necessary styles from my template and gave the levels accordingly.
Please let me know if more information is required. Looking for a solution.
Thank you ![]()
V!ñ@¥
SInce the print worked, let us go to the next stage. Note that with AA9, there was a change in the way the next stage works. To get the bookmarks and such, you have to use the PDF Maker (create PDF selection in newer versions). Open your application and select your document. Then select the Adobe menu and select the create PDF button. You may want to check the preferences first. When reay, complete the create PDF button use. If that does not work, you may have to do a repair of Acrobat. What OS are you using? The OS may be the problem. Also, what subversion of Acrobat are you using. It is up to AA9.3 or later.
North America
Asia Pacific
