Hi All,
I have just written a simple As class using flex builder3 and flex_sdk_4.0.0.10485 surprisingly it shows a dozen of errors
my simple class is
package {
import flash.display.Sprite;
import flashx.textLayout.compose.StandardFlowComposer;
import flashx.textLayout.container.ContainerController;
import flashx.textLayout.elements.ParagraphElement;
import flashx.textLayout.elements.SpanElement;
import flashx.textLayout.elements.TextFlow;
public class HelloWorld extends Sprite
public function HelloWorld()
var textFlow:TextFlow = new TextFlow();
var p:ParagraphElement = new ParagraphElement();
textFlow.addChild(p);
var span:SpanElement = new SpanElement();
span.text = "Hello, World";
span.fontSize = 48;
p.addChild(span);
textFlow.flowComposer.addController(new ContainerController(this, 400, 200));
textFlow.flowComposer.updateAllControllers();
the error lis in Flex builder:
Severity and Description Path Resource Location Creation Time Id
1084: Syntax error: expecting rightbrace before BusyCursor. DemoTLF line 17 1267524161015 177
1084: Syntax error: expecting rightbrace before end of program. DemoTLF line 53 1267524161015 178
1084: Syntax error: expecting rightparen before s. DemoTLF line 17 1267524161000 174
1093: Syntax error. DemoTLF line 17 1267524161000 175
1094: Syntax error: A string literal must be terminated before the line break. DemoTLF line 17 1267524161015 176
I did'nt get whats going wrong any help would be highly appriceated
I'm guessing that its choking on the Vector declarations in playerglobals. Make sure you are targetting player10. With FlexBuilder 3 I recall that was a bit tricky - first turn on generate HTML wrappers if it iisn't already. But then maybe its something else.
Hope that helps,
Richard
Hi ,
Richards thanks for your reply, I am targeting the flash player 10 and generate HTML wrappers is allrady turn on , can you help me that anything else causing it.
Gaurav kumar pandey
By default it will use the SDK that comes with Flex Builder, you will need to add the new SDK, and select it as your target Flex SDK, if you haven't already. That will ensure that it is using the correct version of the compiler when it builds. I don't remember exactly how this is done, but I think if you select "Preferences" there will be an option, perhaps under "ActionScript" for installing the Flex SDK. I would suggest checking to make sure this is done.
Robin , for ur help
I got this , I was pointing the flex sdk which is else in my hard disk
rather then Flex/builder/sdks
What i did i just copy the latesst sdk into Flexbuilder/sdks and this
working fine
Thanks for helping again
Gaurav Kumar Pandey
It sounds like your IDE is building more than just the HelloWorld example, and that the error is in some other file. Have you searched for a class called "DemoTLF"? If you're in Flex, do a multi-file search. "DemoTLF" doesn't sound like something they'd put in the SWC.
