osyrys808
Rotate/duplicate around path
Mar 3, 2010 11:07 PM
Don't know if this is in CS4, or planned for 5.  I'd like to use the rotate tool to duplicate an object around an assigned path, not just around a circle.  And you should be able to control how the objects being duplicated snap towards the center axis.
    Mar 6, 2010 6:27 AM   in reply to osyrys808
    Are you not familiar with Scatter Brushes or Blend>Replace Spine?
    JET
    Mar 8, 2010 5:22 AM   in reply to osyrys808
    You need to describe more clearly exactly what you have in mind. Sounds like redundancy and confusion to me, to associate this with the Rotate Tool.
    JET
    Mar 9, 2010 6:41 PM   in reply to osyrys808
    So far, everything you've described can be done with existing features. I don't know why you would want this associated with the Rotate Tool. Not only is it redundant; "rotating" to duplicate around a non-eliptical path is not very intuitive.
    The only things I would favor in this regard are a couple of long-needed (and long requested) enhancements to existing features:
    PathBlends should be given the option to uniformly distribute (avoiding the add anchorPoints workaround).
    Groups should be distributable along a path.
    The faceting problem of Scatter Brushes should be fixed (again avoiding the add anchorPoints workaround).
    These commonplace capabilities have long been available in other drawing programs.
    JET
