Mar 9, 2010 2:54 PM
mx:tree not getting populated.. help plz!
Like (0)
I am using Flex with BlazeDS. From Java remote object, I am sending an XML and trying to populate that in mx:tree component. The tree component shows no data. Below are code snippets -
.mxml file -
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:ilog="http://www.ilog.com/2007/ilog/flex" layout="absolute" autoLayout="false"
initialize="init(); ">
<mx:RemoteObject id="ro" destination="mgmtConsole"/>
<mx:RemoteObject id="srv" showBusyCursor="true" result="resultHandler(event)" destination="mgmtConsole"/>
<mx:Script>
<![CDATA[
import com.jpmc.ibanker.*;
import mx.events.*;
import mx.rpc.events.*;
import mx.controls.Alert;
[Bindable]
public var myXml:XML;
public function init():void {
srv.getRegionHierarchy();
private function resultHandler(event:ResultEvent):void {
if (event.result != null) {
myXml = event.result as XML;
</mx:Script>
<mx:Tree id="tree" dataProvider="{myXml}" labelField="@label" top="321" left="10"
height="184" width="457" showRoot="false" verticalScrollPolicy="on"
alternatingItemColors="[#FFFFFF,#EEEEEE]"
showScrollTips="true" />
</mx:Application>
.java -
public String getRegionHierarchy() {
return "<root><node label=\"Parent 1\"><node label=\"Child 1\" /><node label=\"Child 2\"><node label=\"Grandchild 1\" /><node label=\"Grandchild 2\" /></node><node label=\"Child 3\" /><node label=\"Child 4\" /></node></root>";
Can someone please help?
try setting up event handlers for the server call:
srv.getRegionHierarchy.addEventListener(ResultEvent.RESULT, resultHandler);
srv.getRegionHierarchy.addEventListener(FaultEvent.FAULT, faultHandler);
private function faultHandler(event:FaultEvent):void {
//handle fault
Basically you must have a handler for each server function that returns some data. Hope this helps.
-sebastian
I do have the event handler attached as part of <mx:RemoteObject>
<mx:RemoteObject id="srv" showBusyCursor="true" result="resultHandler(event)" destination="mgmtConsole">
</mx:RemoteObject>
Also Alert.show(event.result); shows the XML returned from java object.
Am I doing anything wrong with this line - myXml = event.result as XML; ?
I am guessing above line does not assign the XML string coming from java to the myXml variable and as such the tree is not getting populated in <mx:tree>
Finally got it working!
Used below code -
var qName:QName = new QName("root");
var xmlDocument:XMLDocument = new XMLDocument();
var simpleXMLEncoder:SimpleXMLEncoder = new SimpleXMLEncoder(xmlDocument);
var xmlNode:XMLNode = simpleXMLEncoder.encodeValue(event.result, qName, xmlDocument);
myXml = new XML(xmlDocument.toString());
and this is tree -
<mx:Tree id="tree1" dataProvider="{myXml.toString()}" labelField="@label" showRoot="false"
x="10" y="37" height="117" width="195"/>
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
