rjfoster03
Linking issue
Mar 11, 2010 2:01 AM
I am trying to establish an email link that will be at the bottom of each web page.  I highlight the email address, establish the link with mailto:..... and when I am finished, the text disappears due to assuming the color of the background.
I want the email text to be white and underlined.  I have tried several different methods to obtain the results I want, but everything ends up altering the entire site.  All links end up being dramatically changed.
I don't want to affect the entire CSS Style of the site, only the email address to allow it to activate sending an email.  I want the link to remain white/underlined  on the page, while not affecting any other links associated with the site.
I have tried highlighting the text, establishing the link, going down into the Properties box and changing the color- it goes back to matching the color of the background and therefore can not be seen.
I have gone into CSS Styles / Summary for Selection and altered the properties found in the selections.  I can get the results I want, but EVERY other link within the site takes on those properties too.
Any suggestions as to what I am doing incorrectly or how to correct this to make only this link be the way that I want it would be appreciated.
    Mar 11, 2010 2:35 AM   in reply to rjfoster03
    To change the properties of specific links on a page you would target the container in which they are inserted.
    For example if I have a link within a <div> container with the id 'footer' (see below)
    <div id="footer"><a href="something.com">Something Link</a></div>
    I would target that link with css like so:
    #footer a {
    color: #fff;
    text-decoration: underline;
    Mar 11, 2010 4:08 AM   in reply to rjfoster03
    rjfoster03 wrote:
    Thanks for the help....
    If the link is not at the footer, but within a block that is higher up, how do I "name" it or locate it so I can have it to work and be white /underlined?
    Post your pages code here and tell me what link it is you are trying to change.
    Go to code view in Dreamweaver, select it all, paste it in a reply here.
    Mar 11, 2010 7:54 AM   in reply to rjfoster03
    Well first of all if you want the email text to be a clickable link you have to make it a link by wrapping it in an anchor tag (see below)
    I've used xxxxxxx in place of your correct email address. I would edit your orginal post to remove the email address otherwise spam bots will harvest it and you could get a post bag full of rubbish.
    Select the email text and type mailto:xxxxx@xxxxxxxxx.xxx.com (your correct email address) in the link box in the properties inspector box. This will give you the code below:
    <td class="white"><p class="style1">For an indepth proposal and/or pricing, please contact Rice  &amp; Associates, Inc. (336) 370-1555 or e-mail <a href="mailto:xxxxx@xxxxxxxxx.xxx">xxxxx@xxxxxxxxx.xxx.com</a></p></td>
    Next, because the email text is in a <td> cell with the class name 'white', you need to add the below css code to your css style sheet:
    .white a {
    color: #fff;
    Finished.
    Mar 11, 2010 8:25 AM   in reply to rjfoster03
    rjfoster03 wrote:
    I will try the coding, but I am now trying to find out how to edit the post.
    I do not see any button allowing for this, so am I missing something?  I only see an edit function with this posting.
    Humm........... maybe the edit feature is time sensitive and is deactivated. That's stupid
    Mar 11, 2010 8:59 AM   in reply to rjfoster03
    rjfoster03 wrote:
    I did post something earlier with regards to spacing between paragraphs. Any suggestions?  lol
           I've supplied an answer to that in your other thread.
