Mar 11, 2010 1:05 AM
Switching from Flash-AS2 to Flex
Like (0)
Hello !!! I am new in this flex tech
I have made a project in AS2 with Flash. and communicating with the data through XMLs
here is that link http://sanjoghelpline.in/Application_RWSS/default.asp
Now I have to play with large set of data with graphs, grids, different options etc on this maps. I think Flex will be best for it. it will directly connect to the database to fetch datas. I am planning to use webservice.
So I need your suggestion and tips for this. And what serverside language I should choose.
Good choice. Best you can do is making a new project with Flex Builder.
Probably you can use (parts of) your existing AS2 code (be aware of the differences with AS3).
Is there a particular reason why you want to use webservices?
If not, you can considering calling the data-XML's directly by HTTPService for example.
This tool will help as well:
http://www.adobe.com/devnet/flex/tourdeflex/web/#sampleId=0;illustInde x=0;docIndex=0
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
